🧨 44 MAGNUM FAST MOVERS: CHRONOGRAPH RESULTS PORTED VS NONPORTED 🧨
Started by mr.revolverguy, November 02 2020 08:09:02 PM MST
mr.revolverguy
Believe it or not in over 20 years of reloading I have never pushed the edge like I have with these loads in 44Magnum. I always look for accuracy first and velocity second.
With encouragement from a friend I decided to load up some 44 Magnum fast movers. By the way though not seen in the video these loads were worked up to, even though they were considered to be book safe being 1 full grain below max.
I wanted to make it a bit more interesting by testing these loads in a ported vs non-ported barrel. This video will display reloading information. This data is not intended to replace the appropriate reloading manuals data and should not be used without verifying and double checking the loads between two different official published reference points — IE reloading manuals. If you elect to utilize any of this data it is at your own risk. As seen these loads were safe in the firearms used.
https://youtu.be/pZ-gyhp6ECo
