9mm Winchester 115gr FMJ
Started by RDub01, October 18 2020 08:32:28 PM MDT
RDub01
Cartridge is from Ammo Manufacture:  WINCHESTER
Muzzle Velocity; Advertised:  1190 fps
Actual Instrumental Velocity:   1190 fps 4.5" barrel
Muzzle Energy; Advertised:  362 Ft/lbs
Brass Make/Head stamp:  WIN 9mm LUGER
Bullet Make/Weight/Construction/Info: Winchester 115g FMJ
Actual Weight:  114.3grs Diameter; .3550" Length; .587"
Crimp diameter:  .3750"
C.O.A.L.:  1.155"
Primer: Brass Colored
Case:  Brass  .752" Long;   57.2grs. w/o primer
Rim Dia; .3877"   Base Dia .3860"
Powder Description/Positive ID/Type/Charge Weight:  AutoComp? Flattened Ball; 5.4 grs.
Thanks RDub...Very nicely done and I concur the powder is Winchester Auto Comp
