9mm +P+ Buffalo Bore 95gr TAC-XP
Started by RDub01, October 01 2020 08:32:30 PM MDT
RDub01
I picked up a SIG P365 SAS for the wife and started looking for a carry load. Wanted something fast to compensate for the short barrel. Found some Buffalo Bore 95gr on-line and ordered it. Also managed to find a box of 40 Barnes 95 TAC-XP online and ordered those.  Haven't been able to find either one on-line since..  The sights are requiring a learning curve to get used to. The idea is to use both eyes, which I do anyway, and superimpose the green dot onto the target.. However managed to shoot a decent group with those Buffalo Bore rounds.. Very impressive ammo.
So I loaded some ammo with the Barnes bullets and loaded a few tenths over the hottest load Barnes listed, which wound up being 6.7grs of Power Pistol. That averaged just under 1200 fps.
If and when these bullets become available again, I'll try some more loads..
This gun, as with other SAS's I've seen, does not have a ported barrel.. Looks like SIG might have given up on the porting idea..
Cartridge is from Ammo Manufacture:  Buffalo Bore 95gr Barnes TAC-XP
Muzzle Velocity; Advertised:  1,374 fps -- Glock 19 4-inch barrel
Actual Instrumental Velocity:   1375 fps 3.1" barrel
Muzzle Energy; Advertised:  N/A
Brass Make/Head stamp:  JAG
Bullet Make/Weight/Construction/Info:  Barnes 95gr TAC-XP Copper HP
Actual Weight:  94.9grs  Diameter; .3545"  Length; .597"
Crimp diameter:  .3760"
C.O.A.L.:  1.117"
Primer: Brass Colored
Case:  Brass  .750" Long;   54.9grs w/o primer
Rim Dia; .3883"   Base Dia .3870"
Powder Description/Positive ID/Type/Charge Weight:  Flattened Ball; 6.9grs.
RDub01, The powder is Winchester Auto Comp!  Very nice
RDub01
RDub01, great job on this...Thanks!
RDub01
Happy to do it Kenk...
So, I scored some more 95gr TAC-XPs from Midsouth and loaded up some with 6.4grs AUTOCOMP, and just for kicks 6.5grs LONGSHOT.
Not knowing exactly where I was with pressure I stopped at 6.4grs., however primers and brass looked fine..  No doubt that a few tenths more would match the factory velocity.
AUTOCOMP really does well here..  Not so much with LONGSHOT.
Reddog81
I'm jealous of the non-ported barrel.   I picked mine up last November and it has the ported barrel.  The sights take some getting used to.
franciscoxds@gmail.com
Im thinking of doing a very similar load with autocomp since i have a p365x macro with a compensator. Autocomp powder is designed with a large amount of gas to keep the muzzle down and the light bullet would be very fast and light recoil. The only thing is that these bullets are really long. Do you think something like 1.160 or 1.150 would work fine so i can add more powder and keep the pressure down?
Underwood offers a 147gr 9mm in +P+ using the Speer Gold Dot bullet. At 1,175 fps  / Muzzle Energy (ft. lbs): 451 it?s no slouch, and carry it in my XDm 3.8 compact
https://underwoodammo.com/9mm-luger-plus-p-plus-147-grain-bonded-jacket-hollow-point/
Hogdon has 6.5 gr of longshot at 1.125 oal at only 27K psi. Auotcomp is at 32k psi with only 5.8gr. That buffalo bore is loaded extremely hot if they are using almost 7gr of autocomp with that long bullet at 1.11 OAL. I wonder which is actually the better powder at +p+ pressures. (AROUND 40K psi)
Hodgdon   Longshot
6.5gr   1,277fps   27,900 PSI
Winchester   AutoComp
5.8gr   1,329fps   32,700 PSI
#10
Underwood 147gr +P+ is also very manageable recoil wise.plus the Buffalo Bore looks to be twice the cost
https://m.youtube.com/watch?v=TMiI8VcPQ3c
RDub01
Wow... That Underwood round is impressive. They have revolutionized the 9mm round. I'll have to find some.
