Hot 40 cal
Started by gadabout, September 03 2020 11:32:23 AM MDT
gadabout
Well it's official the 40 is working as I cleaned and brushed the feed ramp now all rounds feed!!! A friend wanted to polish the feed ramp and I may still do that.  Craig
Muskrat
I polished the feed ramp of a couple of my Glocks with a dremel tool, polishing head, and green jewelers rough. Worked pretty good...doesn't take off enough material to change the profile. Only takes a few minutes.
gadabout
My friend is going to do it as he has done it before. He doesn't use the dremel tool but does it by hand some way.  Craig
gadabout
Boy I got that screwed up!! He did use a Dremel tool with a buffing bit of some kind. But all done now and I will shoot tomorrow weather permitting!.. Craig
gadabout
I posted above but will make this short. I shot the 40 today and the feed issue is still there. I will try FMJ reloads and if that doesn't work give up.  BTW when it shot it was very good. Craig
gadabout
I haven't posted in a while as there hasn't been to much to report. I was still having problems on the first round being a problem to feed out of the mag. The good news is I loaded a bunch of Gold Dot 180g and they seem to feed just fine. I did everything I could think of to try to screw up the feed but it just fed all rounds. So now we are down to the 165g round being the culprit or whatever. I think I have said previously that the Nosler store bought rounds fed and shot great. I am giving up on this for now as I just got in some blue bullets for 9mm and need to load up some of those.  Craig :P
