Underwood 357Sig 125gr Bonded FMJ pull-down
Started by The_Shadow, March 28 2013 01:46:45 PM MDT
Cartridge is from Ammo Manufacture: Underwood 125gr Bonded FMJ
Ballistics Information: 357 SIG
Muzzle Velocity: 1475 fps
Muzzle Energy: 603 ft. lbs
Brass Make/Headstamp: Star Line-Brass
Bullet Make/Weight/Construction/Info; Length 0.5400"/Dia. 0.3555":
125gr. JHP Actual weight 125.6 grains / 124.2 grains / 124.6 grains
C.O.A.L.: 1.1240" / 1.1235" / 1.1330"
Primer: Brass color
Case: Diameter 0.4220" all
Crimp Diameter 0.3785" / 0.3790" / 0.3790" crimp medium
Length 0.8600" / 0.8610" / 0.8600"
Powder Description/Positive ID/Type/ LongShot
Charge Weight:     9.8 grains / 10.0 grains / 10.0 grains
Hodgdon data shows 124gr Hdy XTP using 9.3 grains LongShot @ 1429 fps 37,900 psi (inside MAP)
Max average pressure for the 357Sig is 40,000psi
In the last picture one cartridge was damaged by something putting a dent into the casing...even though Underwood's ammo is over the book listed data of Hodgdon, I don't think that alone was the cause for the KA-Boom.
I still think the incident was related to bullet set back, which in turn caused a sever pressure spike, that resulted in the catastrophic failure of the gun!
This is the ammo from the blown up Glock? The one pictured looks like it has been chambered or something in a bad way. Mark on the front, dent in the middle and marks on the headstamp.
BTW- a review of my notes shows that Double Tap was using 10.0 grains of LongShot under the 125 Speer Gold Dots Loaded in the 9x25Dillon, these ran 1525-1475 fps from my S&W1006 5" conversion :o
BTW the SwampFox 40S&W Ammo 165gr GDHP loading that blew-up another Glock 29 with a 40S&W conversion barrel, was also loaded with 10.0 grains LongShot powder, this being a sever case blowout.
Wow.  Wish we knew what pressure those were loaded to.
Pctechdude
Oddly enough, I've loaded plenty of 357 Sig. I've always used AA#9 and 800-x. With a Speer gold dot 125gr bullet, and 10gr 800-x it's compressed. Virtually eliminates set back and achieves 1450fps from a 4" barrel without going over on pressure.
