Buffalo Bore 10MM 180gr XTP 12/19
Started by mr.revolverguy, December 28 2019 08:36:51 AM MST
mr.revolverguy
Cartridge is from Ammo Manufacture: Buffalo Bore 180gr JHP (Data was provided by Mr.Revolverguy 12/2019)
Muzzle Velocity: 1324 fps Verified with Chronograph
Muzzle Energy: 700 ft. lbs
Brass Make/Headstamp: Starline – Brass
Bullet Make/Weight/Construction/Info; Length 0.619"/Dia. 0.4000": Hornady XTP 180gr. JHP
HP depth 0.106" / HP dia 0.168"
Actual weight: 180.2 grains
C.O.A.L.: 1.251 Measured 10 rounds all very consistent
Primer: Large Pistol Silver color
Case: Crimp Diameter 0.421" Middle Diameter 0.419" Base/Web: Before the extractor groove 0.421?
Powder Description/Positive ID/Type/Charge Weight: Alliant Power Pistol 9.8 grains
💥Danger💥 Do Not try to replicate this load it may cause destruction or bodily harm💥
One of the viewers made a suggestion that I should fire 1 round a piece in each pistol and measure the brass. At first I thought wow that is a lot of work but my dedication to the viewers proved to be what I needed to get this done.
Don't forget to visit the largest 10MM Balistics Database (Self Proclaimed LOL) on the Internet https://docs.google.com/spreadsheets/d/1Fyj-rKIvGOvm4huvb35GaGMlyKhddtUDQhFi9VGrwLk/edit?usp=sharing
mr.revolverguy
OOps sorry about that Shadow, I will try to bring only new fresh and do a better search next time.
mr.revolverguy, there's nothing to be sorry for! Always glad to see if the data matches and performance as it relates to what others see.
It is all good!   ;D
