MAGTECH 180 gr FMJ 10A (Redline 8/19)
Started by The_Shadow, August 15 2019 02:08:40 PM MDT
Cartridge is from Ammo Manufacture: MAGTECH 180 gr FMJ 10A (Redline 8/19)
Muzzle Velocity: 1230 fps
Muzzle Energy: 605 ft. lbs
Brass Make/Headstamp: CBC  - Brass
Bullet Make/Weight/Construction/Info; Length 0.6200"/Dia. 0.4000": 180gr. FMJ MEPLAT 0.2280" (Exposed Lead Base)
Actual weight 180.0 / 179.0 / 180.0 grains   Crimp squeezed bullet to 0.3990"
C.O.A.L.: 1.2525" / 1.2510" / 1.2500"
Primer: Large Pistol Primer Brass color (Cartouche on primer V)  2 ½
Case: Diameter 0.4200" Crimp Diameter 0.4215" (medium) Length 0.9870"
Powder Description/Positive ID/Type/Charge Weight: Magtech 8.2 / 8.2 / 8.2 grains
(Magtech does make their own powders)
Cartridge weight: 269.0 / 268.8 / 270.0
This MAGTECH powder (a flatten ball powder) is very close to Hodgdon LongShot by weight and velocity yield.
I haven't been able to find any info for the MAGTECH powders or loading data as such as they are not even offered as a canister offering.
Teninator
I'd sure like to know what powder they are using. These are one of the few hot loads my DI AR likes.
terdog
I've always liked MAGTECH. Ain't no powder puff load and it USED to be affordable.
Quote from: Teninator on June 16 2021 03:51:32 PM MDT
Using Magtech or Armscor 180gr FMJ bullets w/9.3gr of Longshot, my DI AR runs like a champ. My only issues are mag related.
1230fps for a 180gr bullet isn't really a hot load, it's the beginning of hot. I don't want to hijack this thread. PM me, if you like, and I'd be happy to share what runs in my DI AR using other bullets, powders, etc. Not surprising hint, it's always near the top end.
terdog
When I said "hot", I meant in comparison to other factory range loads. Armscor comes to mind.
Quote from: terdog on March 03 2022 10:09:02 AM MST
I'll take you word for it. I don't think I've ever fired Armscor factory ammo in 10mm. I would add Hornady to that list, as well. It won't reliably cycle my 10mm DI AR. American Eagle comes up a little short, too.
