44 Magnum Factory/Commercial Ammo pulldowns
Started by The_Shadow, January 31 2013 11:09:29 AM MST
I was a little surprised at the velocity. I thought they were going to be an 1100 fps self defense load.
Shot the Starfire .44's today. Weak! Average 1226 FPS/ 801 LBS out of a 7.5" Redhawk barrel.
Got these today Shadow. Did the 180 FMJ version long ago but not the XTP's. More work for you and Raggedyman if he can figure out the gel length needed  :o Underwood 180 and 300 XTP's.
I up for the pull-downs of anything you want to send.  8)
Anthony posted some available ammo today and I grabbed a box of 240 V-Supreme and 240 HP to test.
https://www.pbrammo.com/news/stock-ammunition-update-0
 Today was .44 day and I finally... finally decided to do those Buffalo Bore 340's with everything else. I warmed up and did a bunch, so I knew I would be ready! All from my 7.5" Redhawk:
Remington 180gr JSP Average = 1689 FPS/ 1130 LBS
American Eagle 240gr JSP 1445, 1413, 1416, 1431. Average = 1426.25 FPS/ 1084 LBS
Underwood Ammo 300gr XTP 1174, 1144, 1167, 1177. Average = 1165.5 FPS/ 905 LBS
Underwood Ammo 180gr XTP 1583, 1608, 1620, 1575. Average = 1596.5 FPS/ 1019 LBS
Devastator 260gr Cast 1387, 1313, 1334, 1352, 1349. Average = 1347 FPS/ 1048 LBS
Buffalo Bore 340gr HardCast 1416, 1404. Average = 1410 FPS/ 1501 LBS!!!! Two perfect readings on the only two I had and showed me why they are best shot in certain firearms  :o :o
They 340's actually shot great but did have some push-back burping those big slugs through the barrel. I can see how a big diet of those could probably expand a frame. I like them!
Intercooler Writes...
QuoteBuffalo Bore 340gr HardCast 1416, 1404. Average = 1410 FPS/ 1501 LBS!!!! Two perfect readings on the only two I had and showed me why they are best shot in certain firearms
Where these the ones I pulled-down and sent back to you?
QuoteDevastator 260gr Cast 1387, 1313, 1334, 1352, 1349. Average = 1347 FPS/ 1048 LBS
Where these some of the ones I sent you?  If yes, the velocity readings are closer to what I had @ 1370 average.
  Two more new ones today. Check out the FMJ tip! Different than any other I have seen.
That's interesting looking *  Butt Hole FMJ... LOL  :o
  Someone brought it to my attention today their 10mm V-Supreme ratings have been lowered. I contacted Anthony hoping it is a misprint. He has a good thing going and hope that's all it is!
RMM
That FMJ looks like it might be a frangible.
Richard - G20SF
