Reed’s Ammunition & Research 165 grain Remington Golden Saber provided IC 8/18
Started by The_Shadow, August 31 2018 10:20:22 PM MDT
Cartridge is from Ammo Manufacture: Reed's Ammunition & Research 165 grain Remington Golden Saber (provided by IC 8/2018)
Muzzle Velocity: 1350 fps
Muzzle Energy: 668 ft. lbs
Brass Make/Headstamp: Star Line – Brass
Bullet Make/Weight/Construction/Info; Length 0.5750"/Dia. 0.4005": 165 grain Remington Golden Saber
Actual weigh 165.6 grains  Flat base / Crimp Diameter 0.3930"
HP depth 0.1960" / HP dia. 0.2325" tapered / mouth outside 0.2880"
C.O.A.L.: 1.2575"
Case: Diameter 0.4215" Crimp Diameter 0.4170" (medium) Length 0.9870"
Powder Description/Positive ID/Type/Charge Weight: Alliant Power Pistol9.8 grains
