Which recoil spring?
Started by sgmtino, June 25 2018 01:23:20 PM MDT
sgmtino
I am looking at recoil springs for the Witness stock 2 and its unclear if it should get a "full size" or a "long slide" recoil spring. Any help would be great.
You can call Wolff Gunsprings and ask more specific questions and if you can just buy the 20 lbs spring which most are using.
https://www.gunsprings.com/EAA/WITNESS%20SERIES%20/cID1/mID19/dID100
Fits Full Size Models Only
Recoil springs are available with load-rated specifications to tailor the recoil function to individual needs. Each load-rated recoil spring pak includes an extra power firing pin spring.
For use in:
  Standard Size Models
    Factory Rating: 14 Lb. - 9mm, .45 ACP, Super .38 and 10mm
Extra Power
Extra Power - Pak Contains 1 each extra power recoil springs in 16, 18, 20 and 22 pounds. Three extra power firing pin springs are also included for both EAA and other models. (Stock No 13127)
sgmtino
I ordered the full size one I was wondering if I should have ordered the longslide  stock 2
I used the standard length in my Match.  I think it is the same slide length as your Stock II.  The longslide would be for things like a 6" Hunter or Gold.
