DoubleTap or Buffalo bore
Started by Kenk, May 09 2018 06:40:20 AM MDT
When not using hand loads, I will most often stick with Underwood. If I were to try DoubleTap or Buffalo bore, which of the two are most constant with their advertised FPS, as well as other statistics offered on their site?
Well UW has most everything you would need for 10mm.  Buffalo Bore will likely be closest to meeting their claimed velocities over DT.
I think DT has gone into a more mainstream commercial market, with many cartridge offerings, as they are loading for Colt and Ted Nugent and they could be doing others as well.
Exactly what I was hoping to learn
Thanks again
Buffalo Bore is good ammo.  But it will break the bank compared to Underwood.
#4
In my experience as well, but only from comparing prices, other than that, I love Kevin's  ammo, plus he has been very receptive when I have contacted him with questions
Buckeye63
climb14er
Buffalo Bore... expensive. FMJ 10mm. No longer buy.
Underwood... moderately expensive. 165gr Gold Dot JHP. 10mm. Travel round and B.C. backup.
Double Tap... reasonable. 200gr Hard Cast. 10mm. Backcountry.
Hornady 175g Critical Duty JHP. 10mm. Home defense.
