Ordered some Fenix 10mm ammo
Started by Olgo, May 01 2018 08:38:41 AM MDT
Olgo
Just be sure your pistol have full chamber support.
FenixAmmunition
Also, be sure your grip is fully supported  :))
01deuce
Quote from: Olgo on July 02 2018 01:24:19 PM MDT
You're shooting it through a glock. Do you use a aftermarket barrel?
Olgo
The original barrel. I think I have it confused with the 40sw barrel.
If his G-29 is like mine the factory barrel has enough support and he mentioned having the 21 lbs & 23 lbs recoil springs.  That helps with the dwell time in lock up.  I will caution that while these Glocks are CNC copies some may act differently than others allowing early unlock and increase the unsupported areas.   You need to test and inspect fired casings to see how things look.
Being a handloader helps because I can work several loadings increasing to see where things start to show case expansion above the 0.4340" of the factory chamber...
Having looked inside the Fenix ammo, it is up where others have loaded to.  But being loaded on progressive machines with powder drops the powder charge weights are up & down: example  Hodgdon LongShot  9.4/9.6/9.8/9.8/10.0 grains...
I will say when working this close to the edge of the upper performance I prefer exact precise weights (Match Grade).   In the words of Dirty Harry "A man has got to know his limitations!" ;D
Mike D
Quote from: The_Shadow on July 05 2018 09:25:33 AM MDT
Hmmm that's a bit concerning. That's a lot of variance when running at the limits.
Olgo
I guess as long they don't go over the top limit. Variations are usually the norm for mass production.
If they make match grade ammo then they'll monitor the powder very closely.
May just have to stick with UW for factory offerings
FenixAmmunition
Our max load is 10.0 grains, and we're confident in the equipment.  Variances will always occur with production ammunition regardless of what machines are used.  To date we have not received any complaints of an overcharged round or a damaged firearm with the specifications we are using.
Looking at our data sheets, our powder checks are typically +- 0.2 grains on 10MM.  The lot numbers on our product correspond to actual data, and we keep those records for life.  Our powder drops are checked every 500 rounds for small run calibers and every 1,000-2,000 rounds for long run calibers like 9mm and .40 S&W, depending on what we're making and what equipment we're using.
Grenadier
#58
Just bought some and tried it over the chronograph out of a 6" Kimber Stainless LS. Temperature was 81°F. Elevation 400 ft ASL. Humidity 29.93" Hg. Brass looked good.
Brand Weight Bullet Mfg's V0 Mfg's E0 Observed V0 Observed E0 SD Low         High
FENIX 180gr FMJ 1375 fps 756 ft-lbs 1375 fps 756 ft-lbs 13.57 1355 fps 1383 fps
FENIX 180gr HP 1375 fps 756 ft-lbs 1367 fps 747 ft-lbs 18.07 1347 fps 1390 fps
Olgo
#59
Yep, what they advertised on their site.  8)
