10mm Pet Loads Thread
Started by Hubcap, March 20 2018 04:53:43 PM MDT
gjarcher
#15
Glock G40 OEM 6" barrel
BULLET WEIGHT: 165gr Rainier Plated
CASE MFR.: Starline
PRIMER: CCI300
POWDER: Alliant Power Pistol
CHARGE WEIGHT: 8.4 grains
OVERALL CARTRIDGE LENGTH: 1.250"
VELOCITY: 1267 fps
OTHER DETAILS: Good plinking/target round with very good bullet stability/accuracy to 75 yds
Glock G40 with 7" KKM barrel
BULLET WEIGHT: 200 gr Hornady XTP
CASE MFR.: Starline
PRIMER: CCI350
POWDER: Accurate #9
CHARGE WEIGHT: 12.8 gr.  (12.5 gr in Glock OEM 6" barrel)
OVERALL CARTRIDGE LENGTH: 1.260"
VELOCITY: 1302 fps (1228 fps in Glock OEM 6" barrel)
OTHER DETAILS: Excellent Black Bear Defense/Hunting load. Glock OEM RSA spring a bit light for 7" barrel, might experience slide-frame slam without heavier spring.
BillinOregon
Sure love reading these load workups.  Thanks to all posters.
Yardbird
BULLET WEIGHT: 180gr Berrys FP/Hornady XTP 180GR HP
CASE MFR.: Starline
PRIMER:CCI #300 LPP
POWDER: Blue Dot
CHARGE WEIGHT:10.4 gr
OVERALL CARTRIDGE LENGTH:1.257"
VELOCITY: I don't own a crony
OTHER DETAILS: Very accurate out of stock G-20 Gen4
Benchrst
Load may be over book! Work up your loads!
BULLET WEIGHT: 155 Montana Gold HP
CASE MFR.: Starline
PRIMER: CCI 300
POWDER: #7
CHARGE WEIGHT: 13.0
OVERALL CARTRIDGE LENGTH: 1.255
VELOCITY: 1,469
OTHER DETAILS: G20.4 Dasan 5.15" 20#. Accurate and snappy :)
Benchrst
#19
BULLET WEIGHT: 140 Bayou TC
CASE MFR.: Starline
PRIMER: CCI 300
POWDER: GM3
CHARGE WEIGHT: 5.0
VELOCITY: 1,011
OTHER DETAILS: G20.4 Dasan 5.15" 24# DAT v2. Drops brass at your feet, stupid accurate :)
BillinOregon
Goetztalon
Just loaded a batch of 11.5 grains of blue dot with the 150 nosler jhp,new starline brass and a cci 300 to set if off. If they shoot good which I think they will by all the great reports on blue dot it could be a pet load for the 20!
Goetztalon
Wow those had some thump lol! Pretty accurate also although I might back it down by a couple tenths.
RDub01
BULLET WEIGHT:    180gr.
BULLET MFR-STYLE  Hornady XTP
CASE MFR:           Starline
PRIMER:             Rem 2½
CHARGE WEIGHT:    10.1grs.
C.O.L.                   1.260"
VELOCITY:          1251 fps
OTHER DETAILS:  matches Buffalo Bore 180gr JHP performance
RDub01
BULLET MFR-STYLE: Speer TMJ
CASE MFR.:         Starline
PRIMER:            Rem 2½
POWDER:            3N37
CHARGE WEIGHT:      9.3grs.
VELOCITY:            1187 fps
OTHER DETAILS:       Nice all-around shooting load
RDub01
#25
BULLET WEIGHT:   204grs.
BULLET MFR/STYLE: RCBS swc cast
PRIMER:          CCI 300
POWDER:          BLUE DOT
CHARGE WEIGHT:   9.5grs.
C.O.L.:          1.260"
VELOCITY:        1134 fps
OTHER DETAILS:   NICE WOODS CARRY LOAD
                 SIZED .401"
                 LYMAN ORANGE MAGIC LUBE
                 ALLOY; 50/50 LINO/WW
5½" CIRCLE; 25 YARDS
Chalk up another 10.4 grns BlueDot, 180grn Berrys/XTP, COAL 1.255, Starline brass, CCI LPP, load. I don't have the chronograph data anymore, but I remember it was just under the 1250fps limit of the Berry's bullet out of my Delta Elite.
Pablo
BULLET WEIGHT: 180gr HAP
CASE MFR.: Starline, other
PRIMER: Winchester, others
POWDER: Longshot
CHARGE WEIGHT: 10-10.5gr
OVERALL CARTRIDGE LENGTH: 1.258" (from memory - didn't go look) - but I know I have gone shorter....... :o
VELOCITY: TBD
OTHER DETAILS: This is a gassy load for my 10mm DI AR. Fat walled, tight, fully enclosed chamber - no signs of overpressure.
TXCOONDOG
BULLET WEIGHT: Lee 401- 175 grain cast using WW
CASE MFR.: Starline
PRIMER: WLP
POWDER: Longshot
CHARGE WEIGHT: 8 grains
OVERALL CARTRIDGE LENGTH:1.260"
VELOCITY: 1205 FPS, ES: 24. SD: 8
OTHER DETAILS: RIA 1911, Model 52,000 with a 6" bull barrel
RDub01
BULLET MFR/STYLE:  Hornady XTP
PRIMER:           CCI 300
BRASS:            Starline
POWDER:           AA #9
CHARGE WEIGHT:    14.9grs.
c.O.L.:           1.260"
VELOCITY:         1266 fps
OTHER DETAILS:    One of the most accurate loads I shoot in the G20-SF
Five round group. 25 yds.  Bottom hole is two rounds.
