10mm Pet Loads Thread
Started by Hubcap, March 20 2018 04:53:43 PM MDT
Hubcap
How's about starting a Favorite loads thread for our 10's?  This would NOT be discussion about components or techniques, JUST data. Please make any pertinent comments about your load (MAX, compressed, hunting, self-defense, etc.). My suggestion would be to include the bullet weight in the subject line to make it easier to find what you're looking for?  Template coming....
Sound like a plan???
Hubcap
#1
BULLET WEIGHT:
CASE MFR.:
PRIMER:
POWDER:
CHARGE WEIGHT:
OVERALL CARTRIDGE LENGTH:
VELOCITY:
OTHER DETAILS:
Hubcap
BULLET WEIGHT: 200 Hornady XTP
CASE MFR.: Starline
PRIMER: WW LPR
POWDER: BLUE DOT
CHARGE WEIGHT: 9.4
OVERALL CARTRIDGE LENGTH: 1.255
VELOCITY: 1292
OTHER DETAILS: Safe in my stock G20SF
BULLET WEIGHT: 180 Hornady XTP / HAP
CASE MFR.: Starline
PRIMER: Winchester LPP
POWDER: BLUE DOT
CHARGE WEIGHT: 10.4
Other details - stock G20 / gen 4 with KKM factory length barrel
#4
BULLET WEIGHT: 200 grain Speer Gold Dot (hopefully the newer ones become handloading components)
CASE MFR.: Starline, Federal
PRIMER: CCI 350
POWDER: Hodgdon Longshot
CHARGE WEIGHT: 9.2 grains (handweighed)
OVERALL CARTRIDGE LENGTH: 1.2500"
VELOCITY: 1235 fps
OTHER DETAILS: Speer 200gr Gold Dot HP 9.2gr's Longshot Tested by me from the S&W 1006 with 22 lbs Wolff recoil spring making 1230 to 1240 fps
Tested by Jesse Atkins (Intercooler)
Limited Pro 4.75 Speer 200gr Gold Dot HP 9.2gr's Long Shot 1235, 1248, 1211, 1252, 1239. Average = 1237 FPS/ 680 LBS Nice!
Bullet on the left is #53883 Bullet on the right is #54000
This pet load thing is an awesome idea
BULLET WEIGHT: 180 Xtreme heavy plate enforce
CASE MFR.:Starlne
PRIMER:Remington
POWDER:Blue Dot
CHARGE WEIGHT: 10.4
VELOCITY:
OTHER DETAILS: very accurate in stock g20-3
[/quote]
Do you like the Xtreme heavy plate?
Quote from: Kenk on March 23 2018 01:27:24 AM MDT
I find it just as good in my G20 as the fmj Remington and Montana Gold jacket... price is pretty good too.
Have pulled some after shooting to find no issues and with plating fully intact.
Will have to look into them, Thanks
#10
BULLET WEIGHT: 175 grains
CASE MFR.: Mixed
PRIMER: CCI 300
POWDER: Blue Dot
CHARGE WEIGHT: 10.4 grains
VELOCITY: 1180 - 1200 fps
OTHER DETAILS:  RCBS 175 grain Cast TC SWC and the LYMAN 175 grain Cast TCBB were my all around target play bullets with Rooster Lab Red Zambini till that ran out (no longer made) and now with White Label Carnauba Red Lube
oldman10mm
Firearm S&W 1006
BULLET WEIGHT:Remington 155 JHP
CASE MFR.:Winchester primed case
POWDER:IMR SR4756
CHARGE WEIGHT:10.0
OVERALL CARTRIDGE LENGTH: ?
VELOCITY:1360 Avg.
OTHER DETAILS:IMR SR4756 no longer manufactured,I have a good supply,use it for 9mm,38sp,357M,40S&W,10mm,41M,44sp,44M
POWDER:IMR SR4756
CHARGE WEIGHT:8.0
OVERALL CARTRIDGE LENGTH:?
VELOCITY:1150 Avg
OTHER DETAILS:reduced 10mm load to approximate 40S&W ballistics
S&W 1006
S&W 610 6.5"
oldman10mm...Yes it is a shame they discontinued the SR-4756 as it had great uses across the board for many cartridges.
IMR SR-4756 & & SR-7625 were the very few single base powders left.
oldman10mm
Those are the only two I use,I have a large supply of both as I started buying them when Hodgdon put out the discontinued notice. You'd be surprised how many still unopened containers are still out there.
Started out with 2400 for the Magnums and tried 4756 to get a cleaner burning powder. 4756 gave me the same chronograph figures and burned clean. 7625 is for 38sp and 44sp light target loads. I find that 4756 can be loaded past max recommended without primer cratering and case head expansion and also can be used for 'reduced' loads. My 'nuclear' loads are 4756. Also works fine for the range of projectiles from 95-158 in 357.
S&W 1006
S&W 610 6.5"
sep
BULLET WEIGHT: Montana Bullet Works 200 Grain WFNPB
CASE MFR.: Starline
PRIMER: CCI 300
POWDER: Blue Dot
CHARGE WEIGHT: 9.5 grains
OVERALL CARTRIDGE LENGTH: 1.240
VELOCITY: 1196 fps average velocity
OTHER DETAILS: Chronographed through an STI Perfect 10 with 6 inch barrel. Bullet sized to .401. The charge weight of Blue Dot could safely be increased a little more in this load.
