4949shooter, PBR and The Shadow Chrony results
Started by Intercooler, February 28 2018 05:39:56 PM MST
 In the past I ran the Federal XM1001A and The Shadow sent a few from 4949shooter. Here are the results for the 180gr FMJ:
EAA Limited Pro 4.75" 1062, 1051, 1057. Average = 1056.66 FPS/ 446 LBS
The Shadow
200gr Gold Dot #54000/#53866 7.4gr's Power Pistol
EAA Limited Pro 4.75" 1013, 1071 Average = 1042 FPS/ 482 LBS
200gr Gold Dot #54000/#53883 7.4gr's BE-86
EAA Limited Pro 4.75" 1096, 1099 Average = 1097.5 FPS/ 535 LBS
200gr XTP 8.0gr's Power Pistol
EAA Super Match 6" 1165, 1174, 1140 Average = 1159.6 FPS/ 597 LBS
200gr Gold Dot 7.4gr's (don't know if it was PP or BE-86)
EAA Limited Pro 4.75" 1106 FPS/ 543 LBS
200gr Hornady XTP 8.0gr's Power Pistol
EAA Limited Pro 4.75" 1107, 1097, 1114, 1140 Average = 1114.5 FPS/ 552 LBS
PBR Ammo
155gr Montana Gold loaded to VS
EAA Limited Pro 4.75" 1532 FPS/ 808 LBS
#3
The New Speer 200 Grain Gold Dots from the pull down documentations was suspected to have BE-86 powder.  Based on the results for IC's velocity test it is clear that BE-86 matches the Factory loaded ammo rated at 1100 fps for 5" barrel!
This was the reloaded 200 grain Gold Dots, one was the new style #54000 and the other #53866 the 40S&W contract pulled with known powder as shown.
200gr Gold Dot #54000/#53883 7.4gr's Power Pistol
200gr Gold Dot 7.4gr's *(don't know if it was PP or BE-86)  *This was the original powder from the pull down used with an old style #53883
Remember that the Factory ammo the bullets are also sealed in the casings...it is what made it so difficult to pull and broke the priming pellet loose in the initial pulls.
Thanks IC great results!   ;D
