Just Got My Fourth 10mm Pistol
Started by gandog56, December 18 2017 07:50:05 PM MST
gandog56
EAA Witness in 10mm with a 40mm barrel and spring added to it so I can shoot both calibers. Fourth pistol, one carbine, and one Mechtech 10mm CCU. This is my only double stack in pistols, though. The carbine uses Glock double stack mags, but I do not own any Glocks.
What can I say, I like 10mm.
PCFlorida
Quote from: gandog56 on December 18 2017 07:50:05 PM MST
Very nice, but 40mm barrel? :)
oldman10mm
Nothing wrong with having a 40S&W barrel. Good for range use/plinking,less expensive factory ammo,easier to reload light loads for.
S&W 1006
S&W 610 6.5"
Rojo27
Congrats on new acquisition!   :))
:P A limited edition Bofors.
I have in 10mm two glocks, two EAA's and three 1911's (two are hi capacity).
The Standard full size Witness was my first 10mm purchase, and I think my best.  It is in the holster today, and it stands toe to toe with the G20 for reliability, and exceeds it in handling hot loads.  The only complaint it the Wonder (why the call it a) finish, which I have replaced with a parkerize + cerakote finish.
You won't be unhappy.
PCFlorida
Quote from: Rojo27 on December 19 2017 05:49:00 AM MST
I'm glad someone else caught that :)
He went to Jared's!!!! Well kind of...
Congratulations on your first double stack and Witness!
PCFlorida
Quote from: oldman10mm on December 19 2017 05:41:18 AM MST
He said 40mm, that was the funny part :)
Very Nice Gandog, I came so very close to buying one just like that a few years ago...kind of sad that I didn't... :(
Enjoy that new toy! 8)
brio
Just be careful using the 40 barrel in the 10mm Witness. I have the same setup, when I fired the 40 cal. barrel, the first 5 shots were great, #6, not  so good.  Apparently being the 40 barrel wasn't "fitted" for the witness I had, it jumped a lug. Locked up the gun tighter than a crabs ass, and that is water  tight!! Hammered away at it for awhile with a rubber mallet, couldn't budge the slide forward or backward. So, back to EAA it went. When they received t they asked me which barrel I wanted fitted to  the gun, naturally I wanted the 10mm. 2 weeks later, it was  back at my FFL guys business. I think it cost $50.00 all together, 20 for the return shipping and 30 for their shop charge. I still have the 40 barrel, someday I'll have it fitted.
Best of luck with your new toy!!
gandog56
Quote from: sqlbullet on December 19 2017 08:31:37 AM MST
Actually, I was surprised when I looked up the serial number and saw this was manufactured in 2002. There is not a single mark on the outside on the frame or slide. No signs of any holster wear or anything similar.
gandog56
Quote from: PCFlorida on December 19 2017 03:46:37 AM MST
EAA Witness in 10mm with a 40Cal. S&W barrel and spring added to it so I can shoot both calibers. Fourth pistol, one carbine, and one Mechtech 10mm CCU. This is my only double stack in pistols, though. The carbine uses Glock double stack mags, but I do not own any Glocks.
gandog56
TonyRumore
You can probably get away with using the 10mm spring with both barrels as long as your 40 ammo is full power.
Tony
blaster
nice pistol Ganny. I also got a .40 S&W bbl  and mags. for mine the 10mm  factory recoil springs works great with my .40 S&W loads. my barrel dropped right in and has had many rounds thru it with no problems.
