Reed’s Ammo 165gr Gold Dot Nov 2017
Started by The_Shadow, December 07 2017 05:11:15 PM MST
Cartridge is from Ammo Manufacture: Reed's Ammo 165gr Gold Dot (provided by IC Nov 2017)
Muzzle Velocity: 1350 fps
Muzzle Energy: 668 ft. lbs
Brass Make/Headstamp: A-USA - Brass
Bullet Make/Weight/Construction/Info; Length 0.5770"/Dia. 0.4000": 165gr. Speer Gold Dot
HP Depth 0.1500" / HP Inside Dia.0.2010" tapered / HP mouth Dia. 0.3000"
Actual weight 164.0 / 165.6 grains (concave base)  Crimp squeezed bullet to 0.3925"
C.O.A.L.: 1.2460" / 1.2475"
Primer: Large Pistol primer Nickel color
Case: Diameter 0.4195" Crimp Diameter 0.4205" (heavy) Length 0.9855"/0.9870"
Powder Description/Positive ID/Type/Charge  AA #9   Weight: 14.8/14.8 grains*
*Microbeads
Disregard the the label with 155 grains, when these were taken apart the 165's were in the opposite bag... ::)  Jesse testing me I guess   8)
These shot fire out my barrel. That's my excuse  :P Temporary blindness  ;D
