Underwood Xtreme Penetrators from a 1006, chamber support question
Started by 10-7 leo, September 12 2017 06:39:04 PM MDT
10-7 leo
Would you be comfortable shooting Underwood Xtreme Penetrators with the chamber support this barrel has? I'm concerned with the area at the top of the feed ramp. I am not concerned with reloading the brass, if the rounds need to be fired. Thanks!
The 1006 should handle those just fine.  I use the 22 lbs spring in mine.  Good luck to you!
will965
