Cutting Edge 190 grain copper solid
Started by Ridgerunner665, July 08 2017 06:29:38 PM MDT
Ridgerunner665
#16
Let the Seal Tite band tell you that... Seat it with the band snugged up to the case mouth.
With my brass at .988" - .989", the band seated as described above, leaving the bullet sticking out .266" as CEB recommends.... The overall length comes to ~1.255".
If you haven't already, read the instructions on CEB's website.... The instructions on seating and case mouth chamfering are very important.
Ridgerunner665
13.5 grains will be very compressed, they'll likely settle around 1.26" maybe 1.265".... They fed fine for me at that length though.
That is with new Starline brass, other makes may vary a little in one direction or the other.
Ten Ten
Ridge, I havent had a chance to look at CEB's website, but will soon and before I reload...thanks for the info..;)
Ridgerunner665
#20
I'm on my way home for a couple of days so I'll have some Power Pistol and Longshot data this weekend.
Ridgerunner665
Picture to illustrate where to place the SealTite band...
Ten Ten
Ridge, thanks for the pic, you must have read my mind, I was going to ask for one ;)...Im gunna load some up but wont be able to get out and shoot for awhile
Looking forward to your results as well....
Ridgerunner665
#24
8.4 grains of Power Pistol = 1,177 fps
8.4 grains of Longshot = 1,178 fps.
No surprise there, that they matched.... Every load I've tried with those powders is grain for grain, fps for fps.
I have a few rounds loaded with 8.9 grains of Longshot to test next.
Summary.... Using any other 190 grain load data with these bullets is safe....VERY safe.... Like about 25,000 psi with max listed load safe... I've used Lee and Alliant data.
Remember, I'm using a 7" barrel.
After those 8.9 grain loads mentioned above, I fully expect to have to venture into unknown territory with these bullets, they don't build pressure like other bullets, I'm leaning towards using 180 grain data with them, carefully.
I'm measuring case head expansion, I figure thats the most reliable indicator of pressure I have at my disposal.
Ridgerunner665
#25
8.9 grains of Longshot = 1,243 fps.
Still no case head expansion, but based on the appearance of the cases I am just getting into the proper pressure for the powder to burn like its supposed to.
Primers say the same thing, they're looking like the primers on my 12.6 grains of AA9 with 200 XTP loads.
Ridgerunner665
Ridgerunner665
9.2 grains of Longshot = 1,285 fps....a smile on the brass, and some case head expansion.
Looks like that's as far as Longshot will shoot.
Ridgerunner665
Ridgerunner665
#29
I think before I buy a pound of powder, I'm gonna try AA #9 with magnum primers...
50 mag primers doesn't cost much to try.
So far, nothing has come close to the speed I got with #9... At least not without pressure signs.
