PMC 10 mm Brass Problems
Started by Bayan Dundee, June 19 2017 05:46:10 PM MDT
The Factory Crimp Die with the carbide ring in the bottom is what I use and that is what the bulge buster kit works with...
The bulge buster kit, is only a push pin,screw in thread protector to funnel the brass up and a catch can that sits on top the FCD die with the thread protector in place of guts...
I didn't need the bulge buster kit as I just catch the brass as the start coming out the top anyway and I already had had the pus pin from a previous bullet sizer kit.  It has served me very well doing 10mm / 40S&W / 357Sig / 9x25Dillon cases.  Using the 45ACP FCD I pass through size them as well as using the 380ACP FCD I do those too just for the extra insurance of reliability.
I have pass trough sized 9mm but using the 9mm makarov / 9x18 but they are tight, I want to open the carbide ring up slightly because it doesn't need that much sizing.
Timberhawk
Some days it's just not worth chewing through the restraints!
