Fired Lehigh Defense Extreme Defense Alongside Underwood Extreme Defender
Started by 4949shooter, April 29 2017 03:47:10 AM MDT
I wanted to compare the two loads. As we know, they both use the same bullet.
The Underwood @1700 fps obviously felt stronger then the Lehigh @1500 fps. The Lehigh was no slouch though.
I wouldn't hesitate to carry either in a state like New Jersey, where hollowpoints are illegal. I may carry a variation of these loads upon my retirement from law enforcement.
I would lean towards the Underwood for woods carry.
Sorry no chronograph. And at $38 per box / 20 this ammo is too expensive to send in for a pull down. Sorry guys!
Underwood's Technical Information:
Caliber: 10mm Auto
Bullet Weight: 115 Grains
Bullet Style: Lehigh Defense Xtreme Defense
Case Type: Ducta-Bright 7a Nickel Brass
Ballistics Information:
Muzzle Velocity:1700 fps
Muzzle Energy: 738 ft. lbs.
Penetration:18 inches
We actually did two for pull downs already
Indeed Shadow....I meant for the Lehigh Defense Load. My mistake for not clarifying. See below:
Cartridge:  10mm Auto
Bullet weight (gr):  115
FTM - Fluid Transfer Monolithic
Box qty:  20
Velocity (fps):  1,500
OAL (in):  1.255
Penetration (in):  21.00
Wound cavity (in):  ?3.125
Xtreme Defense is a Register Trademark of Lehigh Defense, LLC.
Utility Patent / Design Patents Pending
My misunderstanding, I thought they were both the Underwood...I haven't had the chance to peek inside the actual Lehigh product.  Seeing they are about 200 fps slower than the Underwood, I have to wonder if they are just reduced charges of what UW
is doing or if they infact are using another powder to make their numbers.
I would like to see what could be done using BE-86 with these to take advantage of the flash suppressants.
