Cast Bullets in 10 MM Auto
Started by TXCOONDOG, April 28 2017 10:40:13 AM MDT
TXCOONDOG
#15
The TC 180 & 200 gr design naturally runs great in my RIA Pro Match with COL 1.250- 1.260. There was no difference in velocities (same charge at different depths) , etc except the 180 gr shot the best groups with a COL of 1.260 and the 200 gr did best with a 1.250".  Boths loads were using longshot powder with WLP primers.
My plans are  to have a custom boolit mold made for 200 or 220gr with a slick side for PC'ing (no lube groove) . However, I'm not sure how wide of a nose I can get to run reliably.
PS: Anyone willing to help me out by sending me 3-5 WFN that I can hand cycle test ?
Randominator
I have some 190 grain with a .300" nose and 230 grain with a .310" I can send.  Is this what you're looking for?  PM me if interested.
HHI # 8053
SCI Member
"get busy living... or get busy dying"
TXCOONDOG
Quote from: Randominator on May 28 2017 09:06:20 AM MDT
Exactly what I'm looking for and willing to pay shipping, etc
Will follow up with PM of my address and any futher discussions.
This is awesome and greatly appreciated
TXCOONDOG
Quote from: TXCOONDOG on May 28 2017 09:11:15 AM MDT
I recieved them. Even with a COL 1.260" they feed flawlessly by hand so time to order a mold or two, maybe three....lol
Greatly appreciate your help.
Let me know if I can ever be of assistance!
Very Nice bullet for PC use without any lube grooves...
TXCOONDOG
Went to the range yesterday to test the 200gr cast TC with AA# 9. I forgot to take a picture of my target before I left or remove it from the stand before placing it in my truck bed so it blew away.
Needless to say, after 10 shoots in the same ragged hole the next 25 did not appear on paper due to going through the same hole......yep, you'll have to take my word.
Bullet: 200 grain TC PB cast, .401"
Lube: 45-45-10
Case: Starline .985"
Primer: WLP
Powder: 12.5 gr of AA# 9
COL: 1.250"
Velocity: 1270 fps ES: 11 SD: 04
Lube: 45-45-10
Primer: WLP
Powder: 13gr of AA# 9
COL: 1.250"
Velocity: 1308 fps ES: 16 SD: 06
I can't wait to get my Arsenal WFN-PC mold.
TXCOONDOG
Quote from: The_Shadow on June 15 2017 06:43:58 PM MDT
I'm excited about it and I also requested a trough be cut in the sprue plate.
Until I recieve it, I have 20lbs of Lee 401-175 TC to work with:
TXCOONDOG
Even though most already know this, I must add my
Disclaimer:
The information listed is for my pistol, for my use only and is intended for information only. If you decide to buy, use, follow, etc based on the information I have provided than you are doing so at your own risk.
BillinOregon
Coondog, that's a heck of a target you posted.
Texashogman
#25
TCD--- what did your bore slug to?? (IIRC it was .400") ---my 52000 slugged at .401" (so did the 40 cal bbl in my p224) ---I ordered some 200wfn's at .402" from montana---he is hi-tek coating them for me to be a guinea pig for him on the coating
Springfield 10mm osp,
5 dollars waiting on 5 cents
TXCOONDOG
#26
Mine slugged at .401"-.401.5" (4 measurements)
At velocities below 1100 and a bhn of 15 and higher, I run .402-.403 because it doesn't obturate fast enough to seal the bore to prevent gas cutting and leading.
However, using COWW + 2% tin   which has a BHN of 11 and running a180gr between 1200- 1300plus, I can get away with a diameter of .401" without any leadings issues.
PS: I forgot to mention that those are powder coated and/or lubed w/ a plain base design (no gas checks)
Timberhawk
I'm running the MiHec 200 grain bullet as shown on the attached link.
http://castboolits.gunloads.com/showthread.php?171093-Mihec-10mm-200gr-WFN-40s-amp-w-180gr-HP-4-cavity-Brass
Been loading it with Blue Dot.
Haven't had a chance to wring it out completely, but is accurate with every load I've tried.
Some days it's just not worth chewing through the restraints!
