Gearing up to reload
Started by CurtisM, April 05 2017 04:51:37 PM MDT
Bat Rastard
My neighbors dog has been telling me some very disturbing things lately. I just ignore him because everybody knows that dog is crazy.
Benchrst
Quote from: Bat Rastard on April 08 2017 03:50:05 PM MDT
Who likes BE-86 ?
BE-86 seems to be close to PP, but without the velocity.
The Earl o Sammich
Who likes V V 3N38 and/or 3N37 for a lighter bullet, besides me?
Benchrst
Quote from: The Earl o Sammich on April 08 2017 07:25:34 PM MDT
Both work pretty nice with 155's :)
CurtisM
Purchased a Redding passthru die and ran all of my brass thru it last night.  Had one piece of brass that I scrapped since it had a smile in it.  Hope to get some test rounds loaded up this evening to see how the WSF is going to work.
G20 - Gen 4 (first 10mm as of 4/2017)
NRA Member
KSRA Member
CurtisM, Sounds great!  Yes yet another advantage of Pass-Through sizing as it gives another inspection opportunity!  You should be fine using the book loadings from Hodgdon with the WSF.
If you are new to reloading, be sure you are reading you scale correctly.  Having check weights can help or having a second scale to verify against each other is nice.  Good luck!
CurtisM
Thanks The_Shadow for the feedback.  I ran just over 10,000 rounds through my Dillon in the last 12 months, but all were 9mm.  Starting out cautiously with the 10.
NRA Member
KSRA Member
Geeman
Who likes BE-86 ?
Its a good 10mm powder.
I stepped up loadings until I was around the level of Underwood 180g.  The gun was a stock Glock 20 (Gen4) and there were no smiles, but standard deviation was increasing with every tenth of a grain added to the loads.  I believe this was reaching the limits of the stock spring which translated to reduced uniformity.
The thread is...
http://10mm-firearms.com/reloading-10mm-ammo/be86-180g-xtreme-g20-step-up-loads/
Greg
PCFlorida
I agree with that statement. I have gotten PP (one of my favorites) velocity out of BE-86.
