Cartridge is from Ammo Manufacture: Remington UMC 115 gr FMJ L9mm3 IC 8-18
Ballistics Information: 9mm
Muzzle Velocity: 1135 fps
Muzzle Energy: 329 ft. lbs
Brass Make/Headstamp: Remington RP – Brass
Bullet Make/Weight/Construction/Info; Length 0.5575"/Dia. 0.3550": 115 gr. FMJ
Actual weight 114.8 grains (exposed lead flat base) Crimp line 0.3550"
C.O.A.L.: 1.1130"
Primer: Small Pistol Brass color
Case: Diameter 0.3870" Crimp Diameter 0.3765" Length 0.7485"
Powder Description/Positive ID/Type/Charge Weight: AutoComp 5.4 grains
Pctechdude
Purchased the 124gr bonded jhp +p+ from underwood received a 147gr variant. These differ slightly from the original that was posted some time ago. Seems powder and overall length has changed. I contacted Underwood ammo and did notify them these were not what I ordered. Received a call from Kevin personally and was told I would be given a new box. He did confirm it is not autocomp in these when I asked lol  ;D
Cartridge is from Ammo Manufacture: Underwood 147gr bonded jhp +P+
Ballistics Information: 9mm +P+
Muzzle Velocity: 1175 fps
Muzzle Energy: 451 ft. lbs
Brass Make/Headstamp: Underwood - Nickel
HP depth 0.2075" / HP dia. 0.1260" / mouth 0.2135"
Actual weight 147.0 grains
C.O.A.L.: 1.116"
Primer: Nickel color
Case: Diameter 0.3875" Crimp Diameter 0.3770" Length 0.7480"
Powder Description/Positive ID/Type/Charge Weight: ? 5.5gr - 5.6gr was fluctuating
#317
Pctechdude, Good catch on that being the wrong bullets and seating depth being different too...
The 147 gr GD pull-down info which pretty much matches the powder charge exactly, could just be a different powder lot #.
Being the wrong bullet the C.A.O.L. may also be problematic as seated too deep.  The ballistic data on the box suggest that it is for the 124 grain bullet
12/2013 Pull down
Underwood 9mm 147gr Speer Gold Dot JHP +P+
Muzzle Velocity: 1250 fps
Muzzle Energy: 509 ft. lbs
Brass Make/Headstamp: Speer - Brass
Bullet Make/Weight/Construction/Info; Length 0.6590"/Dia. 0.3555": Speer Gold Dot 147gr. JHP
C.O.A.L.: 1.1370"
Primer: Brass color
Powder Description/Positive ID/Type/Charge Weight: ? AutoComp ? 5.6 grains
Pictures of AutoComp powder
My own batch of AutoComp
Pctechdude
Shadow thank you, Whats funny is according to their website, the 147 grain load was out of stock  :o The tips of the bullets are a little mashed down, so I'm not exactly sure. I did receive the 124's that I initially ordered so I will post those too.
Pctechdude, With those 147 grain  you might want to adjust the cartridge overall length to 1.1370" - 1.1400", it looks like you have the tools to do so.  That should help pressures stay where they should be.
I'll be looking for you post of the 124 grains to see what you find in those.  We may see the same or different, so my interest is peaked!
Thanks!
Pctechdude
Received the correct ammunition from underwood yesterday, here are the results. Also including unfired and fired case from my M&P Full size 9mm and empty case weight and case holding water.
Cartridge is from Ammo Manufacture: Underwood 124gr bonded jhp +P+
Muzzle Velocity: 1300 fps
Muzzle Energy: 465 ft. lbs
Bullet Make/Weight/Construction/Info; Length 0.5700"/Dia. 0.3555": Speer 124gr. GDHP
HP depth 0.1225 / cavity tapered / HP mouth 0.2215"
Actual weight 123.3grains
C.O.A.L.: 1.113"
Powder Description/Positive ID/Type/Charge Weight: Autocomp? 6.3gr
Pctechdude
Quote from: The_Shadow on April 05 2019 09:24:05 AM MDT
Thanks!
If the brass is like the 124gr +p+ and is holding 14.2 gr of h2o they may be seating deeper to get the same results? But I can definitely adjust these that's for sure lol!
Running it in quickload with the numbers just as a rough simulation and using the Alliant Herco profile which tracks almost identical to autocomp, 5.6gr, 14.2gr h2o and 1.116" C.O.A.L nets 43804k psi and 1146 fps.
Even utilizing 13.8gr which is an average of starline cases with 6.4gr herco profile, 124gr gold dot and the seating depth of 1.113" I get 1291 fps and 42682 psi. This calculation has been almost spot on for me and load development working with autocomp.
The new 124 grain seems to match up to the previous 124 grain pull down as well although they were Nosler Bullets.
Pctechdude
Quote from: The_Shadow on April 05 2019 09:03:52 PM MDT
That was my thought too. I'll get some chronograph data hopefully tomorrow when I'm at the range [emoji16]
Sent from my Moto Z (2) using Tapatalk
Pctechdude
Really disappointed in the results of both the loads. I fired 3 of each, 124gr +p+ and the 147gr +p+.
M&P 9mm FS 4.25" barrel.
124gr +p+
1223fps
1221fps
1222fps
The velocities were close but not close to advertised. Must be why I didn't see much case expansion.
The 147gr +p+ was just as bad, was able to record 2 shots, 3rd showed error. I reluctantly fired them as they were shipped. No adjusting of the overall length.
However the 3 test rounds I made to duplicate these were right in line with the factory stuff. So that is a positive in saying that it is autocomp.
147gr +p+
1099 fps
1106 fps
1102 avg
Intercooler tested the +P+ in various weights and even the one I sent him which was a 121 grain ZERO 0.356" bullet
His 1/2" longer barrel would not have made that much difference...  I have to wonder if these newer loads had standard primer and the older a magnum primer? ???
QuoteAugust 23, 2013
Underwood 115gr +P+ Speer Gold Dot Limited 4.75": 1469, 1473, 1473. Average = 1471.66 FPS/ 553 LBS
February 22, 2014 Test Underwood 115gr +P+ Gold Dot EAA Limited 4.75" 1493 FPS/ 569 LBS
Underwood 115gr Gold Dot +P+ Hunter 6": 1540, 1565, 1532, 1519, 1527, 1530. Average = 1535.5 FPS/ 602 LBS.
About a 65 FPS increase over the 4.75" Limited barrel. I guess if you have a 4.5" -4.75" barrel you are getting about all you can out of 9mm rounds.
November 30, 2013
Underwood 124gr +P+ Nosler EAA Elite Limited 4.75" 1366, 1385, 1369, 1397, 1370, 1381, 1380. Average = 1387 FPS/ 530 LBS
February 22, 2014 Test Underwood 124gr +P+ Nosler Eaa Limited 4.75" 1397 FPS/ 537 LBS
Underwood 147gr +P+ Gold Dot EAA (Limited 4.75") 1265, 1271, 1244, 1268, 1261. Average = 1261.8 FPS/ 520 LBS
February 22, 2014
Shadow's 121gr Zero +P+ Auto Comp 6.4gr's (Underwood 124gr load)... wait for it.....
EAA Limited 4.75" 1376 FPS/ 521 LBS
Pctechdude
Quote from: The_Shadow on April 06 2019 08:05:38 PM MDT
November 30, 2013
February 22, 2014
Im Not sure, I know previously, I tested some 124's after speaking with you Shadow and formulating some idea's around overall length and 6.4gr of Autocomp, using the gold dot bullet. Those all chronographed out at 1300 ± a few fps. That was with a standard primer. Looking at the data from the previous 147gr +p+ those were with a brass colored primer. These were nickel plated primers in these cases.
Looks like I may have to test some of these theories, now to procure some small pistol magnums, or even try small rifle?
Pctechdude
Hopefully I can get out Friday, got my order of the Speer 124gr bullets and some starline nickel plated brass today.
I loaded 18 rounds, 6.4gr Autocomp, C.O.A.L. 1.113" just like the Underwood ones. Only difference is I used a Winchester primer.
Once I test these, I'll post the results. Hopefully they fare better than the ones I bought.
Pctechdude
So was able to get out and test some of the 124gr +p+ rounds yesterday. Unfortunately, my old chronograph stopped working and had to order a new one. Really liking the pro Chrono over my old shooting chrony.
124gr Speer gold dot
Winchester small pistol primer
6.4gr Autocomp
1.113" overall length
I did drop these on my uniflow powder dispenser and not electronic powder dispenser.
