Pctechdude
#285
Pulled another Speer gold dot 124gr +p and got a measurement without the sealant. Still the same at 6.7gr.  Accurate arms/ramshot shows +p loadings with a OAL of 1.105" and silhouette for 6.0gr and AA#5 at 6.3gr. so with the increased cartridge length I'm thinking AA#5. As with silhouette we've seen quite a few pulldowns use 6.8gr silhouette for +p+ loadings?
What's your thoughts?
I was shocked to see a ball powder inside the case, I would of put money on seeing BE-86. I know from experience using a 6.3gr charge with a 124gr gold dot I get 1240+fps from my glock 19. I tested these in my shield and had less case expansion than the factory stuff!
Sent from my XT1585 using Tapatalk
#286
Cartridge is from Ammo Manufacture: Tulammo 115gr FMJ Silver Bullet (provided by Intercooler 11/20/16)
Ballistics Information: 9mm
Muzzle Velocity: 1150 fps
Muzzle Energy: 338 ft. lbs
Brass Make/Headstamp: Tulammo – Steel
Bullet Make/Weight/Construction/Info; Length 0.6170"/Dia. 0.3550": 115 gr. FMJ
Actual weight 115.0 grains (exposed lead base)(steel jacket) Crimp line 0.3545"
C.O.A.L.: 1.1625"
Primer: Brass color (Berdan)
Case: Diameter 0.3880" Crimp Diameter 0.3760" Length 0.7490"
Powder Description/Positive ID/Type/Charge Weight:  ? Vihtavuori N340?  5.0 grains *
*Possible powders N340 (irregular short cut rod)
#287
Cartridge is from Ammo Manufacture: RWS 85gr NTF(Non-Toxic Frangible) Copper Matrix CM9 (provided by Intercooler 11/20/16)
Muzzle Velocity: 1426 fps
Muzzle Energy: 452 ft. lbs
Brass Make/Headstamp: RWS – Brass
Bullet Make/Weight/Construction/Info; Length 0.6720"/Dia. 0.3555": 85 gr. NTF
Actual weight 85.4 grains (Copper Matrix)(Non-Toxic Frangible) Crimp line NA
C.O.A.L.: 1.1310"
Primer: Small Pistol Nickel Color
Case: Diameter 0.3875" Crimp Diameter 0.3790" Length 0.7475"
Powder Description/Positive ID/Type/Charge Weight: ? Ramshot Silhouette?  6.4 grains * (fine flatten ball)
Copper Matrix NTF Bullets contain no toxic heavy metals such as lead. Frangible bullet construction immediately disintegrates into small fragments upon striking a hard steel surface. Back splatter is eliminated. Ricochet potential is significantly reduced. Copper Matrix NTF ammunition functions reliably with duty weapons without modification.
Ruag Ammotec Usa Inc.
#288
Quote from: The_Shadow on November 20 2016 01:32:17 PM MST
C.O.A.L.: 1.1625"
Less powder and different powder than the old Gold bullet version. Interesting!
#289
Cartridge is from Ammo Manufacture: Winchester USA Forged Steel Cased 115gr FMJ (provided by Intercooler 11/20/16)
Muzzle Velocity: 1190 fps
Muzzle Energy: 365 ft. lbs
Brass Make/Headstamp: WIN Winchester – Steel
Bullet Make/Weight/Construction/Info; Length 0.5935"/Dia. 0.3545": 115 gr. FMJ
Actual weight 115.4 grains (exposed lead base)(concave base) Crimp line 0.3535"
C.O.A.L.: 1.1590"
Primer: Small Pistol Brass color
Case: Diameter 0.3890" Crimp Diameter 0.3760" Length 0.7455"
Powder Description/Positive ID/Type/Charge Weight:  ? AutoComp ?  5.2 grains *
* could be a special derivative of AutoComp (flatten ball)
#290
Cartridge is from Ammo Manufacture: PMC 9A 115gr FMJ (provided by Intercooler 11/20/16)
Brass Make/Headstamp: PMC – Brass
Bullet Make/Weight/Construction/Info; Length 0.5930"/Dia. 0.3550": 115gr. FMJ
Actual weight 115.4 grains (exposed lead base)(concave base)(black sealant) Crimp line NA
C.O.A.L.: 1.1560"
Case: Diameter 0.3865" Crimp Diameter 0.3775" Length 0.7500"
Powder Description/Positive ID/Type/Charge Weight: ? ? 4.0 grains *
*(very fine flatten ball silvery color) (powder is similar to TightGroup but more energetic)
#291
Cartridge is from Ammo Manufacture: Browning Performance Target PBT 115gr FMJ (provided by Intercooler 11/20/16)
Brass Make/Headstamp: Browning BuckMark – Brass
Bullet Make/Weight/Construction/Info; Length 0.5870"/Dia. 0.3545": 115gr. FMJ
Actual weight 114.6 grains (exposed lead base)(concave base) Crimp line 0.3505"
C.O.A.L.: 1.1620"
Case: Diameter 0.3860" Crimp Diameter 0.3745" Length 0.7475"
Powder Description/Positive ID/Type/Charge Weight: AutoComp 5.4 grains *
*(fine flatten ball silvery color) Designed to match the BXP Personal Defense
#292
Cartridge is from Ammo Manufacture: Federal HST 150gr HST HP (supplied by Intercooler 11/20/16)
Muzzle Velocity: 900 fps
Muzzle Energy: 270 ft. lbs
Brass Make/Headstamp: Federal Cartridge – Nickel
Bullet Make/Weight/Construction/Info; Length 0.6920"/Dia. 0.3545": FED 150gr. HST
HP depth 0.1650" / HP dia 0.1830" (tapered) / HP mouth 0.2260"  Six long segments
Actual weight 149.6 grains   (flat base) (Cannelure) (black sealer)
C.O.A.L.: 1.1185"
Primer: Small Pistol Nickel color
Case: Diameter 0.3855" Crimp Diameter 0.3775" Length 0.7470"
Powder Description/Positive ID/Type/Charge Weight: AutoComp 4.0 grains
tdogg
Wow! I had to register just to thank you for this wealth of information!  Tons of good info in this thread!  Most notably the muzzle velocities, bullet lengths, and the cartridge overall lengths.  Really helpful when doing your own load development and need to compare seating depths with published load data and your particular components.
Thanks again!
Cheers,
Toby
#295
Cartridge is from Ammo Manufacture: Winchester USA Forged 115gr FMJ Steel (Provided by Intercooler Nov 2017)
Brass Make/Headstamp: Winchester WIN – Steel
Bullet Make/Weight/Construction/Info; Length 0.5955"/Dia. 0.3535": 115 gr. FMJ
Actual weight 115.6 grains (concaved exposed lead base) Crimp line 0.3520"
C.O.A.L.: 1.1610"
Primer: Small Pistol - Brass color - boxer
Case: Diameter 0.3890" Crimp Diameter 0.3740" Length 0.7480"
Powder Description/Positive ID/Type/Charge Weight:  ? Proprietary ?  5.2 grains *
* (flatten ball could be AutoComp)
#297
Cartridge is from Ammo Manufacture: GBW Cartridge Legend Pro CHP 115gr SCHP
Brass Make/Headstamp: JAG – Nickel +P
Bullet Make/Weight/Construction/Info; Length 0.6860"/Dia. 0.3550": CHP 115 gr.
HP depth 0.2260" / HP dia 0.1740"
Actual weight 114.2 / 114.4 grains (slight concave base) Crimp line 0.3535"
C.O.A.L.: 1.1295" / 1.1300"
Primer: Small Pistol Nickel color - boxer
Case: Diameter 0.3865" Crimp Diameter 0.3750"/03760" Length 0.7500"
Powder Description/Positive ID/Type/Charge Weight:  Bullseye  4.2 / 4.2 grains *
(fine flake)
I think that's the first with Bullseye so far. It looks kind of like Power Pistol?
Yes except the flakes are a little smaller and thinner for Bullseye and it is a faster burning powder than Power pistol...
