#195
Cartridge is from Ammo Manufacture: Remington 124 gr FMJ
Ballistics Information: 9mm
Muzzle Velocity: 1050 fps
Muzzle Energy: 303 ft. lbs
Brass Make/Headstamp: Remington RP  – Brass
Bullet Make/Weight/Construction/Info; Length 0.5960"/Dia. 0.3550": 124 gr. FMJ
Actual weight 124.2 grains (exposed lead flat base) Crimp line 0.3545"
C.O.A.L.: 1.1040"
Primer: Small Pistol Nickel color
Case: Diameter 0.3855" Crimp Diameter 0.3770"  medium Length 0.7480"
Powder Description/Positive ID/Type/Charge Weight:  Power Pistol  4.8 grains
#196
Cartridge is from Ammo Manufacture: Sellier & Bellot (Police) 115gr FMJ
Muzzle Velocity: 1200 fps
Muzzle Energy: 367 ft. lbs
Brass Make/Headstamp:  Sellier & Bellot S&B  – Brass
Bullet Make/Weight/Construction/Info; Length 0.5730"/Dia. 0.3555": 115 gr. FMJ
Actual weight 115.2 grains (concaved exposed lead base)(black sealant) Crimp line 0.3545"
C.O.A.L.: 1.1600"
Primer: Small Pistol Nickel color (full green sealant)
Case: Diameter 0.3890" Crimp Diameter 0.3775" Length 0.7510"
Powder Description/Positive ID/Type/Charge Weight:  ? WSF ?  5.6 grains *
* (fine  flatten ball)
#197
Cartridge is from Ammo Manufacture: ZVS 115 gr FMJ
Muzzle Velocity: 1100 fps
Muzzle Energy: 308 ft. lbs
Brass Make/Headstamp: ZVS – Brass
Bullet Make/Weight/Construction/Info; Length 0.5690"/Dia. 0.3550": 115 gr. FMJ
Actual weight 115.2 grains (concaved exposed lead base) Crimp line 0.3530"
C.O.A.L.: 1.1585"
Primer: Small Pistol Brass color
Case: Diameter 0.3890" Crimp Diameter 0.3765" Length 0.7490"
Powder Description/Positive ID/Type/Charge Weight:  ? LOVEX DO36 ?  5.4 grains *
#198
Cartridge is from Ammo Manufacture: American Eagle 115 gr FMJ
Muzzle Velocity: 1150 fps
Muzzle Energy: 337 ft. lbs
Brass Make/Headstamp: Federal FC – Brass
Bullet Make/Weight/Construction/Info; Length 0.5965"/Dia. 0.3550": 115 gr. FMJ
Actual weight 115.0 grains (concaved exposed lead base) Crimp line 0.3545"
C.O.A.L.: 1.1515"
Case: Diameter 0.3885" Crimp Diameter 0.3760" Length 0.7490"
Powder Description/Positive ID/Type/Charge Weight:  Power Pistol  4.6 grains
#199
Cartridge is from Ammo Manufacture: American Eagle 124 gr FMJ
Bullet Make/Weight/Construction/Info; Length 0.5965"/Dia. 0.3550": 124 gr. FMJ
Actual weight 123.0 grains (exposed lead base) Crimp line 0.3545"
C.O.A.L.: 1.1500"
Case: Diameter 0.3850" Crimp Diameter 0.3765" Length 0.7485"
Powder Description/Positive ID/Type/Charge Weight:  Power Pistol  4.2 grains
#200
Cartridge is from Ammo Manufacture: Priv Partizan Ammo PPU 124 gr  FMJ
Muzzle Velocity:1099 fps
Muzzle Energy: 331 ft. lbs
Brass Make/Headstamp: PPU  - Brass
Bullet Make/Weight/Construction/Info; Length 0.6130"/Dia. 0.3545":  FMJ 124gr.
Actual weight 123.0 grains (concaved exposed lead base) (black sealer)
C.O.A.L.: 1.1535"   crimp line 0.3525"
Primer: Brass color
Case: Diameter 0.3875" Crimp Diameter 0.3750" Length 0.7510"
Powder Description/Positive ID/Type/Charge Weight: square cut flakes gray color? 5.4 grains *
*(proprietary powder)? (SIPE) (Vectan Nobel Sport A0) (VihtaVuori N3SH) (VihtaVuori N3SL) ?
#201
Cartridge is from Ammo Manufacture: GECO 124 gr  FMJ
Muzzle Velocity:1180 fps
Muzzle Energy: 382 ft. lbs
Brass Make/Headstamp: GECO - Brass
Bullet Make/Weight/Construction/Info; Length 0.6135"/Dia. 0.3540":  FMJ 124gr.
Actual weight 122.8 grains (concaved exposed lead base)
C.O.A.L.: 1.1500"   crimp line 0.3535"
Primer: Brass color
Case: Diameter 0.3865" Crimp Diameter 0.3760" Length 0.7475"
Powder Description/Positive ID/Type/Charge Weight: ? RamShot TrueBlue ? 6.0 grains
#202
Cartridge is from Ammo Manufacture: Sellier & Bellot (Non Police) 115gr FMJ
Brass Make/Headstamp:  Sellier & Bellot S&B 14  – Brass
Actual weight 115.6 grains (flat exposed lead base) Crimp line 0.3510"
C.O.A.L.: 1.1595"
Case: Diameter 0.3880" Crimp Diameter 0.3755" Length 0.7480"
Powder Description/Positive ID/Type/Charge Weight:  ? HP-38 / W231 ?  5.2 grains *
* (fine irregular flatten ball)
#203
Cartridge is from Ammo Manufacture: Winchester 115 gr Kinetic HE JHP
Muzzle Velocity: 1300 fps
Muzzle Energy: 431 ft. lbs
Brass Make/Headstamp: Winchester – Nickle WIN
Bullet Make/Weight/Construction/Info; Length 0.5395"/Dia. 0.3545": 115 gr. HEJHP
HP depth 0.2600" / HP cavity tapered" / HP mouth 0.1800"
Actual weight 115.2 grains (flat base) Crimp line 0.3480"
C.O.A.L.: 1.0890"
Primer: Brass color
Case: Diameter 0.3855" Crimp Diameter 0.3735" Length 0.7460"
Powder Description/Positive ID/Type/Charge Weight:  ? AutoComp ?  6.4 grains *
(dark very fine flatten ball) ?
#204
Cartridge is from Ammo Manufacture: Speer Lawman 115gr FMJ #53615
Muzzle Energy: 368 ft. lbs
Brass Make/Headstamp: Speer – Brass
Bullet Make/Weight/Construction/Info; Length 0.5700"/Dia. 0.3550": Speer 115gr. FMJ Actual weight 115.0 grains   (concave base) crimp line 0.3545"
C.O.A.L.: 1.1525"
Primer: Small pistol Nickel color
Case: Diameter 0.3875" Crimp Diameter 0.3760" Length 0.7490"
Powder Description/Positive ID/Type/Charge Weight: BE-86 6.6 grains *
(has soft translucent grey color off white flakes)
#205
Cartridge is from Ammo Manufacture: Israel Military Industries IMI 115 gr Ex-Star JHP
Brass Make/Headstamp: IMI – Brass
Bullet Make/Weight/Construction/Info; Length 0.5320"/Dia. 0.3545": IMI 115 JHP
HP depth 0.1370" / HP cavity (has a step) 0.1160" / HP mouth 0.1910"
Actual weight 115.0 grains (stamped recessed base) (black sealant)Crimp line 0.3540"
C.O.A.L.: 1.0610"
Case: Diameter 0.3875" Crimp Diameter 0.3780" Length 0.7520"
Powder Description/Positive ID/Type/Charge Weight:  ? WSF ?  5.4 grains*
*(foreign made ammo could be proprietary)
#206
Cartridge is from Ammo Manufacture: Israel Military Industries IMI 115 gr FMJ
Bullet Make/Weight/Construction/Info; Length 0.5780" /Dia. 0.3545": IMI 115 FMJ
Actual weight 115.2 grains (exposed lead base) (black sealant)Crimp line 0.3540"
C.O.A.L.: 1.1580"
Primer: Small Pistol Brass color (red sealer)
Powder Description/Positive ID/Type/Charge Weight:  ? Silhouette ?  6.2 grains
*(Foreign powders can be proprietary)
#207
Cartridge is from Ammo Manufacture: Israel Military Industries IMI 124 gr FMJ
Muzzle Energy: 333 ft. lbs
Bullet Make/Weight/Construction/Info; Length 0.5780" / Dia. 0.3555": IMI 124 FMJ
Actual weight 124.8 grains (exposed lead base) (black sealant)Crimp line 0.3540"
C.O.A.L.: 1.1600"
Case: Diameter 0.3880" Crimp Diameter 0.3770" Length 0.7520"
#208
Cartridge is from Ammo Manufacture: Magtech 115 gr JHP 9C
Muzzle Velocity: 1155 fps
Muzzle Energy: 340 ft. lbs
Brass Make/Headstamp: CBC – Brass
Bullet Make/Weight/Construction/Info; Length 0.5500"/Dia. 0.3545": 115 gr. JHP
HP depth 0.2640" / HP dia 0.1170" (tapered) / Mouth 0.2000"
Actual weight 115.0 grains (dimpled flat base) Crimp line 0.3530"
C.O.A.L.: 1.1110"
Primer: Brass color
Case: Diameter 0.3855" Crimp Diameter 0.3770" Length 0.7465"
Powder Description/Positive ID/Type/Charge Weight: ? Magtech ?  5.6 grains *
*(reason for ? marks is Magtech does make their own powders) (similar to Power Pistol)
  For the IMI rounds, does it look the the 115 Ex-Star uses the same 124 FMJ powder and the 115 FMJ is a different one?
