The Underwood GD 115gr had 7.0gr's. This has been scaled back?
The Nosler 115 grain bullet was 0.3545" they seem to run smaller in diameter less drag and maybe less accurate.
Other factors can be seated depth of the bullet to powder charge.
#107
Cartridge is from Ammo Manufacture: Underwood 9mm 147gr Speer Gold Dot JHP +P+
Ballistics Information: 9mm +P+
Muzzle Velocity: 1250 fps
Muzzle Energy: 509 ft. lbs
Brass Make/Headstamp: Speer - Brass
Bullet Make/Weight/Construction/Info; Length 0.6590"/Dia. 0.3555": Speer Gold Dot 147gr. JHP
HP depth 0.2075" / HP dia. 0.1260" / mouth 0.2135"
Actual weight 147.0 grains
C.O.A.L.: 1.1370"
Primer: Brass color
Case: Diameter 0.3875" Crimp Diameter 0.3770" Length 0.7480"
Powder Description/Positive ID/Type/Charge Weight: ? AutoComp ? 5.6 grains
Tested by Intercooler 02/01/2014; Underwood 147gr Gold Dot JHP +P+ Springfield XD 4" Average = 1208 FPS/ 476 LBS
#108
Cartridge is from Ammo Manufacture: Dynamic Research Technologies DRT 9mm 85gr Terminal Shock frangible
Muzzle Velocity: 1450 fps
Muzzle Energy: 396 ft. lbs
Brass Make/Headstamp: DRT - Brass
Bullet Make/Weight/Construction/Info; Length 0.5290"/Dia. 0.3545": DRT TS 85gr.
HP depth 0.1370" / HP dia. 0.1265" / HP mouth 0.2150"
Actual weight 84.8 grains
C.O.A.L.: 1.0330"
Primer: Brass color
Case: Diameter 0.3870" Crimp Diameter 0.3765" Length 0.7490"
Powder Description/Positive ID/Type/Charge Weight: ? HP-38 / W231?  5.0 grains
Tested by Intercooler 02/01/2014; DRT Technologies 85gr Frangible +P Springfield XD 4" Average = 1425 FPS/ 383 LBS
#109
Cartridge is from Ammo Manufacture: GECO 115 gr JHP
Muzzle Velocity: 1200 fps
Muzzle Energy: 340 ft. lbs
Brass Make/Headstamp: GECO – Brass
Bullet Make/Weight/Construction/Info; Length 0.5250"/Dia. 0.3540": 115 gr. JHP
HP depth 0.1750" / HP cavity 0.0960" / HP Mouth 0.2125"
Actual weight 115.2 grains (flat base) (black sealer)
C.O.A.L.: 1.0570"
Primer: Brass color
Case: Diameter 0.3890" Crimp Diameter 0.3765" Length 0.7480"
Powder Description/Positive ID/Type/Charge Weight:  ? ?  5.2 grains *
(very fine flatten ball)
Tested by Intercooler 02/01/2014; Geco 115gr JHP Springfield XD 4" Average = 1131 FPS/ 327 LBS
#110
Cartridge is from Ammo Manufacture: Doublet Tap 165 gr Equalizer 115 gr. JHP / 50 gr Lead FN +P
Muzzle Velocity: 995 fps
Muzzle Energy: 365 ft. lbs
Brass Make/Headstamp: Double Tap DT – Nickel
Bullet Make/Weight/Construction/Info; Length 0.5400"/Dia. 0.3550": 115 gr. JHP
Lead FN 50gr. Looks like a short wad cutter with a gas check Dia 0.3535"
115gr. Nosler JHP Actual weight 116.4 grains / Lead FN Actual weight 48.6 gr
HP depth 0.1945" / HP cavity 0.1340" / HP mouth 0.1935"
Actual weight 165.0 grains (flat base) Crimp line 0.3545"
C.O.A.L.: 1.1145"
Primer: Nickel color
Case: Diameter 0.3835" Crimp Diameter 0.3785" (Light) Length 0.7485"
Powder Description/Positive ID/Type/Charge Weight:  LongShot  4.6 grains
They are interesting, but I would like to see a gel test.
#112
Cartridge is from Ammo Manufacture: CCI Blazer Herter's 115gr Total Nylon Jacket TNJ
Muzzle Velocity: 1140 fps
Muzzle Energy: 331 ft. lbs
Brass Make/Headstamp: CCI – Aluminum  NR
Bullet Make/Weight/Construction/Info; Length 0.5790"/Dia. 0.3540": 115 gr. TNJ
Actual weight 114.8 grains (Blue Total Nylon Jacket concave lead core) Crimp line 0.3525"
C.O.A.L.: 1.1550"
Case: Diameter 0.3865" Crimp Diameter 0.3760" Length 0.7480"
Powder Description/Positive ID/Type/Charge Weight:  ? ?  6.0 grains *
(fine flatten ball powder)
 The TNJ isn't much below a +P. I would buy them again.
I have looked over a bunch of my data and picture files and I have nothing using that much powder with under 1200 fps.  It is probably a proprietary powder.  Still looking for possibilities!  Closest powder visually was the stuff Fiocchi was using in their 9mm.
#115
Cartridge is from Ammo Manufacture: Remington 115 gr +P JHP High Terminal Performance (RTP9MM6)
Muzzle Energy: 536 ft. lbs
Brass Make/Headstamp: Remington – Brass +P
Bullet Make/Weight/Construction/Info; Length 0.5330"/Dia. 0.3550": 115 gr. JHP
HP depth 0.1970" / HP cavity 0.1340" / HP mouth 0.1935"
Actual weight 115.0 grains (flat base) Crimp line 0.3550"
C.O.A.L.: 1.0820"
Primer: Nickel color (red sealant)
Case: Diameter 0.3855" Crimp Diameter 0.3770" Length 0.7480"
Powder Description/Positive ID/Type/Charge Weight:  Bullseye  5.6 grains
 That's a new one. I don't know how you can tell because they are starting to look all the same to me  :o
#117
Cartridge is from Ammo Manufacture: Hornady Critical Duty 135gr Flex Lock +P
Muzzle Velocity: 1010 fps
Muzzle Energy: 306 ft. lbs
Brass Make/Headstamp: Hornady – Nickel +P
Bullet Make/Weight/Construction/Info; Length 0.7125"/Dia. 0.3545": 135 gr. Flex Tip
Actual weight 135.2 grains (rounded heel) Crimp line 0.3390"
HP mouth 0.2000" filled with red polymer tip
C.O.A.L.: 1.1410"
Primer: Brass color (red sealer)
Case: Diameter 0.3860" Crimp Diameter 0.3750" Length 0.7495"
Powder Description/Positive ID/Type/Charge Weight:  ? HS6 ? 5.6 grains *
May be HS-6 given the weight and length of the bullet and velocity... :-\
#119
Cartridge is from Ammo Manufacture: Black Hills 115gr Hornady XTP +P
Muzzle Velocity: 1300 fps
Muzzle Energy: 431 ft. lbs
Brass Make/Headstamp: Black Hills Ammo BHA – Brass +P
Bullet Make/Weight/Construction/Info; Length 0.5410"/Dia. 0.3550": Hornady 115gr. XTP
HP Depth 0.1630" / HP dia 0.0930" tapered / Mouth 0.2000"
Actual weight 114.8 grains  / crimp squeeze 0.3530"
C.O.A.L.: 1.0835"
Primer: Brass color
Case: Diameter 0.3865" Crimp Diameter 0.3750" Length 0.7485"
Powder Description/Positive ID/Type/Charge Weight:  Power Pistol 6.8 grains
