10MM Rimmed case
Started by usrguns, September 25 2016 08:11:14 PM MDT
usrguns
Has anyone ever attempted to get some rimmed cases for the 610, so you do not have to use moon clips????  I am new to this forum and would like to know your thoughts.
Thinking you would have to make them yourself....  41 mag cases maybe
usrguns
Actually have a custom ammunition friend who thought of this and is attempting to make some for me to try for him.  If they work he is going to make me a bunch to play with!!  He might also offer them to other 10mm shooters if there is a market for them.
oldman10mm
Since I shoot/reload both 10mm and 41M,a 10mm die will/does size down a 41M case to 10mm size except for the solid head area in the primer area. That section/area would have to be machined down. Once that's done,trim to length and it should work. I'll make one up and do a picture.
S&W 1006
S&W 610 6.5"
BEEMER!
I would think that the 41 case would have to be neck reamed once it is trimmed also.
Maybe not?
I dislike messing with moon clips also.  I just shot my 610 with out them and picked the cases out by hand.
41 magnum base diameter is too big.  Not sure how you would size it all the way down with the rim in the way.
I would start with 30-30 brass if it was my project.  It would have to be inside reamed after trimming to length, and you may wish to cut the rim down a bit as the rim is huge on the 30-30.
But, otherwise it is a good match.  As you would expect since it is in the parent lineage of the 10mm.  30-30-> 30 Remington -> 10mm Auto.
oldman10mm
In reply I said I would do pic.
41M made into a 10mm. Trim length is that for 10mm. The lower head end that is solid and not sizeable with the 10mm die had to be spun in the drill press and a file was used to reduce that diameter.
41M on left,standard 10mm on right.
both inserted in a 610 as far as they would go in against the chamber shoulder,a moon clip would hold the 10mm out a little further by a few thousants. the 41M doesn't go in far enough to seat against the rim so it would have to be trimmed slightly shorter than a 10mm trim length. both would go in a little further once a crimp was applied with a finished cartridge.
S&W 1006
S&W 610 6.5"
Pinsnscrews
Nice work! Thanks for taking the time to do that.
It's my DiMMe
oldman10mm
Also,added note,measuring from rim down to bottom solid head area,the modified 41M case has 7% less capacity than the 10mm case. So without going to a slightly faster burn rate powder,velocities would be slower. But for reduced power target loads,it would be nice to insert cartridges as a normal revolver,even though for competition events,removing a moon clip full of spent cartridges and reloading with a full moon clip of ammo will always be faster.
Potentially,shorten the 41M even more for a rimmed 40S&W case.
Sometime in the future,I'll be making 12 to simulate 10mm and 12 to simulate 40S&W,probably not till late winter and then I'll post back.
S&W 1006
S&W 610 6.5"
happy trails
" He might also offer them to other 10mm shooters if there is a market for them."
I'd be interested in such a product.
oldman10mm
#10
Tried a different parent case as suggested in post#6,a 30-30.
Much easier,just required a tube cutter cut at the proper dimension.
10mm,41Mag,30-30
trimmed case length a little more compared to previous post so they would seat against cylinder.
Rim diameter on the 30-30 is virtually the same as the 41m. Since the 610 is an N frame and is used for 45 LC,rim diameters will not contact each other.
wall thickness for the 10mm and 41Mag is .009",30-30 is .012". Have to see if a bulge from seated bullet will cause a problem
S&W 1006
S&W 610 6.5"
oldman10mm
#11
Finally acquired a box of Herters 401 Powermag ammo at today's Akron show, so now this project from about 5 years ago can move forward.
I'll start by pulling apart one of them, de-prime and throw the brass in the wet tumbler, run it thru the 10mm sizer and trim length to 10mm spec.
I'll report as info is acquired.
S&W 1006
S&W 610 6.5"
Randy Shelley made some rimmed 10mm magnum cases (not what parent case was)
oldman10mm
#13
Disassembled 10 of them, ran them thru a 10mm sizer die, left 2 of them at original length, trimmed 8 to length. Of those 8, one used for a dummy round (no powder or primer) to assess visual, one used for a cutaway to assess internal visuals, and 6 to be used in 610 for load testing.
S&W 1006
S&W 610 6.5"
oldman10mm
The 401 Mags contained a 200gr LRN bullet and 11.0grs of powder. Being that the ammo was made in Sweden, I wouldn't guess what the powder was.
S&W 1006
S&W 610 6.5"
