10mm gel tests
Raggedyman
10mm hand load fired from EAA Witness through four layers of denim. 155 gr Barnes TAC-XP over 8.0 gr of 800-X, new Starline brass, Winchester LP primer. Data is noted in the video and in video description.
Not too bad.  I still like the 155gr Gold Dot best from what you tested.
Raggedyman
Video:
10mm Underwood 135 gr Nosler JHP fired from EAA Witness 4.5" barrel through four layers of denim into calibrated gelatin.
BB calibration: 591.4 fps, 3.3"
Impact velocity: 1,568 fps
Penetration: 7.9"
Retained weight: 80.4 gr
Max expansion: 0.745"
Min expansion: 0.529"
pacapcop
The gel went total airborne,ouch.
Good one, thank for posting it.
Good video.  I am still up in the air about super light bullets in 10mm.  I know lots of guys really like them, and there are some impressive videos of them.  I even have some at home. But I still, deep down, just better trust a 200 grain that will go 15" +.
Raggedyman
I concur. Penetration is king in handgun bullets and it doesn't matter how brutal the tissue disruption is if it doesn't drive deeply enough to do it to vital organs and major blood vessels.
165 and 180 grain JHPs do well in 10mm too, though. I'd reserve the 200+ gr bullets for large animal defense.
What ones have gone 15" plus?
Raggedyman
Underwood 220 gr HC
PPU 180 gr JHP
Black Talon 200 gr
Handloaded 200 gr XTP @ 1,133 fps
Corbon 180 gr BCSP
    Of those which ones failed to expand?
Raggedyman
The Underwood HC (obviously), The PPU, and the Corbon.
That leaves only the XTP and the Black Talon for expanding bullets offering >15" of penetration from what I've tested so far. The Black Talon is, of course, no longer available. Does anyone know if there is a Ranger T .400" 200 gr bullet available as a component? That's the same bullet as the Black Talon but without the black coating. I'd also like to test the Nosler 200 gr when I get a chance.
I have not seen the Ranger T's offered as component items...more people would probably use them if they did.
How about a .400 A-frame bullet? Such an animal?
I dont' think any of the bullets are having issues with core separation, so I don't see where an a-frame buys you much.  The A-frame solves the issue of long, high velocity rifle bullets that lacked penetration due to core separation.
Some food to chew on with definitions of all the bullets:
http://www.littlestonesrus.com/The-Bullets_ep_47.html
My thought was just that it may be available in a heavy weight and drive deeper since it's being used for Magnum rounds at Magnum speeds. I sent Chopinbloc a couple of A-frames for .357 and .44. Let's see what the gel says!
