BE86 - 180g Xtreme - Short Barrel step-up loads
Started by Geeman, July 17 2016 03:04:37 PM MDT
Geeman
Same loads as I ran in the Glock.  This time it was the Tanfoglio Compact Steel and its 3.6" barrel.  5 shot strings.
8.4g
Forgot to arm the Labradar for the first shot.
Shot ID   V0
1   1146
2   1135
3   1130
4    1137
Stats - Average   1137.1   fps
Stats - Highest   1146.38   fps
Stats - Lowest   1130.02   fps
Stats - Spread   16.36   fps
Stats - Std. Dev   6.82   fps
8.5g
Shot ID   V0
1   1135
2   1131
3   1135
4   1148
5   1136
Stats - Average   1137.12   fps
Stats - Highest   1148.43   fps
Stats - Lowest   1130.74   fps
Stats - Spread   17.69   fps
Stats - Std. Dev   6.66   fps
8.6g
The slide locked back twice like it was the last shot in the mag during this series.  Was the mag not all the way in?
Shot ID   V0
1   1135
2   1157
3   1162
4   1150
5   1145
Stats - Average   1149.88   fps
Stats - Highest   1162.29   fps
Stats - Lowest   1135.16   fps
Stats - Spread   27.13   fps
Stats - Std. Dev   10.65   fps
8.7g
Shot ID   V0
1   1150
2   1173
3   1166
4   1170
5   1154
Stats - Average   1162.56   fps
Stats - Highest   1173.47   fps
Stats - Lowest   1149.78   fps
Stats - Spread   23.69   fps
Stats - Std. Dev   10.17   fps
8.8g
Shot ID   V0
1   1165
2   1145
3   1178
4   1175
5   1168
Stats - Average   1166.27   fps
Stats - Highest   1178.04   fps
Stats - Lowest   1145.4   fps
Stats - Spread   32.64   fps
Stats - Std. Dev   12.76   fps
Greg
Wow the data is welcomed and shows what I saw from the Sig Sauer 180 FMJ ammo I did the pull down on.  Thanks once again!  8)
Glock 29 Factory BBL Wolff 21lbs Spring set, velocity 1178 fps   case expansion    0.4315"
