What is your favorite mild to medium 10mm loads?
Started by Dieselman, May 24 2016 10:19:28 PM MDT
Dieselman
So does anyone else here have a favorite milder 10mm load that they want to share?
I have never used WSF or Unique before.
PCFlorida
#16
6.8 grains of power pistol under a 180 -name your flavor- of bullet. Anything you have, cast or FMJ is fine. Has always cycled all my guns, is reliable and remarkably accurate.
Taterhead
I have a few:
6.5 gr WSF 180 gr Powerbond
8.0 gr No. 5 180 gr Powerbond
4.5 gr 452AA 200 gr FMJ (could swap for WST)
5.4 gr 452AA 180 gr coated cast (could use WST)
Quote from: Dieselman on May 25 2016 06:04:21 PM MDT
WSF. Winchester Super Field. Very good for many mid-range (non-magnum) loads, shotgun or handgun. Excellent for full-power 9mm, .38Spl, .44Spl, .40SW, .45LC, .45ACP, etc.
Unique. Well, it's unique. Excellent powder for mid to low-upper range loads in just about any handgun or shotgun, and a lot of low to mid range rifle. If I were limited to only one powder for all loads, Unique would be it, .32ACP to .45-70 (and probably .50BMG, if I had one). The powder meters well, and is very forgiving.
You could try Longshot or Accurate #9 or #7 starting loads.  Maybe even reduce them a bit more.  Problem is powders tend to want a certain minimum pressure to burn well.  Which is why you often see guys going to faster powders rather than reduced charges for their "plinking" loads.
I can load Blue Dot down to 1050 to 1100 for a 180, but I will end up with lots of dirty residue and unburned powder.  And it won't make enough pressure to properly obturate lead bullets so leading becomes an issue.
