180gr Berry Plated TC at the range
Started by RDub01, February 29 2016 11:23:15 PM MST
Benchrst
Greg_Peeples
#16
Would 10gr of power pistol be my max. I like knowing my limit. And how fast is that gonna be? Thanks for your help. I'm brand new to 10mm not reloading. All the info I can get helps. Most of the old timers are passed on.
#17
Greg_Peeples. your 165 grain bullets with a 10.0 grain load of power Pistol will be at or over 1440 fps..and may have a case blow out depending on case support and casing being used...
But lets us know how you make out!  Be safe!
Greg_Peeples
I will. Probably stop at 9.5. This pistol is way more comfortable to shoot than the .40 ever was. That's why I wanted it.
Greg_Peeples
Sorry forgot to say thanks. Hard to find good info.
Greg_Peeples
9.5 cycled the pistol. Everything up to that I had a couple jams. No pressure signs. Should I try a 9.6 or 9.7?
Sent from my iPad using Tapatalk
That's a question only YOU should answer.  Every gun is a bit different and also how accurate are your loads?
Greg_Peeples
Yeah I thought that after I put the tablet down
You'll find that usually the max/fastest loads aren't the most accurate... you have to sort of find the sweet spot for your gun.
Whether to go up higher is a choice based on what your trying to do and how careful you are doing it.  :)
