10mm Handgun Spec Sheet
Started by sqlbullet, November 25 2015 10:37:18 AM MST
ottoman
#30
STI Perfect 10
Total 44.8 with mag
Slide assembly 25.0
Barrel 6.5
Bare slide 15.7
Here are the Bren Ten Specs...
Bren Ten Standard Model Weight empty 38-39 oz with magazine (38 oz Wooden Grips) - 34 oz without magazine
Barrel weight / Slide / Recoil 17 oz
Frame weight 17 oz
Slide weight 12 oz
Barrel weight 3 oz
Bore 0.3990" (as best I can measure)
Bren Ten Military & Police Weight empty 38 oz
Bren Ten Special Forces Weight empty 33 oz
Bren Ten Dual Master Weight empty 33 oz
The Bren Ten Standard model aligns VERY closely with an EAA Witness full size steel.
Interesting! I didn't know they made four models.
GoldBead
Quote from: Captain O on December 23 2015 07:35:13 PM MST
The sig P220 reminds me of a cross between the S&W Model 1006 and the Bren Ten full-sized model. I think this pistol, or the Glock 20 would be the best pistol for the US Marines to carry into combat. Thread the barrel for a suppressor and you'd be "good to go".
Captain O
Hell Yes! A sub-gun in 10mm would be breath taking. Even with 180 grain FMJ, we are talking well over 700 ft/lbs of 10mm.
"Hokey Religions and Ancient Weapons are no match for a good Blaster by your side, Kid."
undeRGRound
OK, got a new Witness Hunter coming, looking for info on this one such as compatibility with full power 10mm (I have a LOT of Underwood!) Also looking for grips, and a threaded barrel, ~6.6" or so total length.
I take it that the 4.7 under Barrel for the 6" W.H. is barrel weight in ounces?  I like a 3# handgun, especially for the hotter loads  ;D
gandog56
I can't find no 10mm Witness's locally to see if a double stack would even fit in my small short fingered hand.
I am sticking to single stacks till I can feel one. But I do have a 6 inch one.
The dimensions should give you a good feel. I think if you don't mind the feel of a 1911, the Witness will be just so much better.
gandog56
Yes, well my 1911's are single stack. The reason I never got an LAR Grizzly, or a Coonan .357, or a Desert Eagle is my hand will not fit around huge grips. I am uncomfortable with Glock double stacks, are EAA Witness's any better?
gandog56
Well dang it, there is not one gun store here I know of that stocks them!
bnolsen
Tanfoglio EAA Witness all steel wonderfinish 2004
full weight: 41
without mag: 37.5
slide assembly: 17.2 (henning)
barrel: 4oz
frame: 19oz
bnolsen
Tanfoglio Witness compact full steel wonderfinish 2003
full weight: 36.2
without mag: 33.5
slide assembly:  15 (henning)
barrel: 3.8
frame: 17.2
bnolsen
#43
Glock 20 gen2 (pre clinton ban)
full weight: 31 (with hogue, glockmeister metal guide rod):
without mag: 28.2
slide assembly:  21
barrel: 5.8
frame: 6.5
ugh math doesn't add up on this one...also imprecise analog scale
anthaynes96
Glock gen4 G40 10mm MOS
Gun without mag 2lb 0.50 oz
Gun with loaded mag. with 180 fmj 2lb 12.75oz
Slide assembly: barrel and spring still in. 1lb 11.55oz
Barrel  5.90oz
Slide 1lb 4.90oz
Factory spring 0.75oz
Frame 5oz
Sent from my SM-G935V using Tapatalk
