Underwood 10mm 180grTMJ report
Started by RDub01, September 25 2012 06:46:43 PM MDT
RDub01
EdMc
Wow, that is quite a spread in velocities. For some reason I remember a post somewhere that had higher velocities with a stronger spring, not less. That could be my memory. :o
Are smileys normal with Underwood loads? I've never tried any......
RDub01
I don't know if they are normal..  This is my first experience with Underwood ammo.
#3
RDub01, Did you find any small "Tan" color flakes in the powder charge? ???
If you did find some tan colored flakes it would indeed be 800X.  I actually did see some in the picture you posted...Thanks!
MrRedbull616
RDub01
yeah...Like you mention.  The velocity variation is consistent with trying to meter 800X.  At least my experience.
