Springfield Custom Shop - 2 New 10mm
Started by PalmBeach, August 28 2015 07:01:50 PM MDT
PalmBeach
PC9102
Custom fit slide to national match frame
Custom fit match bull barrel
Polish feed ramp & throat barrel
Springfield Custom™ tool steel match hammer & sear
Fitted ultra-low mass trigger w/custom tuned trigger pull
Tuned for total reliability
Lowered & flared ejection port
Tuned & polished extractor
Standard GI guide rod system
Custom fit beavertail grip safety
Extended single side thumb safety
Low mount Warren Tactical rear sight, no dots or inserts
Dovetail gold bead front sight
Beveled & polished magazine well
Bobtail rear of frame & mainspring housing
Tactical grips, modified for bobtail
Hand checkered front strap, 25LPI
Magnaport slide & barrel
Modified meltdown carry bevel
Melonite finish
2 magazines
Contact Springfield Custom™ for complete details –
800-617-6751 or custom@springfield-armory.com.
1911 Custom Carry Bobtail®, 10mm
PC9301
Custom fit long slide to national match heavy frame
Custom fit match bull barrel, fully ramped & supported
Fitted aluminum trigger w/custom tuned trigger pull
Full length recoil spring guide assembly
Low mount Springfield adjustable rear sight, std. Bomar cut
Dovetail front sight, fiber optic inserts
Machine checkered front strap, 25LPI, high as possible
Ball cuts on slide
G10 grips
Hand checkered flat mainspring housing (25LPI)
Standard carry bevel
Premium Melonite finish
2 magazines
TightLines
Quote from: TightLines on August 29 2015 11:29:46 AM MDT
I'm dense, what does this post mean?
It means, if you are an oil tycoon or have recently won the lottery, you should call Springfield Custom and order a newly-available 10mm pistol.
Wolfie
TightLines
I didn't realize the above was a copy and paste from the SACS website.
I'm not sure what these two guns being added to the site really changes. SACS has been making custom 10mm builds for years.
Instead of designing your own build they now also offer two models with fixed options?  Maybe the long slide is new?
I'm sure someone can enlighten me.
Glad to see 10mm getting the press.
