which powder ?
Started by hnusz, April 08 2015 11:30:04 AM MDT
Yes I have used the RCBS 5-10 balance beam since 1978 ;D, and had never really had any check weights to test it.  However I bought a FrankFord Arsenal digital, that you see in the pull-downs, it came with check weights, so I used them to test the RCBS and it was on the money perfect after all these years.  The other thing is the two scales agree with each other...
But with time the digital scale does drift and needs to be re zeroed often, so I learned to deal with its limitations when working with it.  ::)
Taterhead
One important, but infrequently discussed, thing is where you put the scale. If the scale is on the same surface that the press is mounted to, the impulses from press operation can move the zero. Scales are ideally placed on a surface that is isolated from the press.
hnusz
Going to order the rcbs and some check weights made an adjustable stand at work to set it on and keep it level
Taterhead
Quote from: hnusz on April 30 2015 06:37:05 PM MDT
Nice. You'll be all set for a LONG time.
hnusz
just ordered the rcbs 505 45$ shipped should be here next week
Taterhead
cwlongshot
I scored a pound of #7 yesterday!!  woohoo!!!!
CW
REMEMBER FREEDOM IS NOT FREE!
gandog56
I scored a pound of Hodgdon BL-C(2).  ;D
Well I had been looking for a 8lb jug of BE-86 and found it and a pound of 800X and some primers to make that purchase worth the Haz-Mat fee, then a local guy sold me 2 pounds of Power Pistol, my current powder stock is up to snuff now... ;D
hnusz
Picked up a pound of #9 yesterday have not seen any #5
gandog56
Quote from: hnusz on August 22 2015 02:17:42 PM MDT
Never tried #5. Have used #7.
nemloc
Quote from: gandog56 on August 21 2015 06:37:52 PM MDT
do you use BL-C(2) for 10mm?
nemloc, welcome to the forum!
BL-C 2 is a slower small rifle powder and not suitable for the 10mm as such.  Haven't even seen where anyone tried it either. Sorry... ???
gandog56
Quote from: nemloc on September 06 2015 08:19:48 AM MDT
Nah, but I am going to try it for 7.62X54R, 8X56R, .308 Win, 30.06, 7.7 Jap, 7.5 Swiss, 6.5 Swede. For 10 mm I have Red Dot , Blue Dot, HP-38, 800X, Unique if I had to.
