10mm pull downs
Started by Julian537, April 06 2015 02:35:32 PM MDT
cwall64
Quote from: The_Shadow on May 05 2015 07:19:56 PM MDT
Wow, I have seen others that have had them shed the inside cores, but it was usually being struck on steel or concrete surfaces.  Using the end grain of the 4x4 helps to get things out without the harsh shock of a unforgiving surface.
I like the collet operation just too cheap to buy them I suppose! ::)
Funny thing, I was setting up my new Dillon XL650 and I got one that I couldn't pull with the die puller (couldn't get a tight enough grip) - so I used your trick of hitting wood (whole firewood log on end) and it worked perfectly!  So, thanks for the tip!!!
Houston, TX
Glad it worked for you  8)...We can all learn new things... :D
