Underwood 200gr Hard Cast (IC 3/4/2015) Pull-Down
Started by The_Shadow, March 05 2015 02:22:30 PM MST
Cartridge is from Ammo Manufacture: Underwood 200gr Hard Cast (provided by IC 3/4/2015)
Muzzle Velocity: 1250 fps
Muzzle Energy: 694 ft. lbs
Brass Make/Headstamp: Underwood  - Brass
Bullet Make/Weight/Construction/Info; Length 0.7360"/Dia. 0.4010": Hard Cast 200gr. HC actual weight 196.4 grains  / Meplat 0.2870"  (flat base) (blue lube)
C.O.A.L.: 1.2490"
Case: Diameter 0.4220" Crimp Diameter 0.4225" Length 0.9865"
Powder Description/Positive ID/Type/Charge Weight: LOVEX D037-01 11.6 grains*
*(Very similar to AA#7 by weight)
  Even though supposedly the powder was an experiment, we are seeing it in everything.
