1911 springs
Started by hogslayer, February 22 2015 01:03:11 PM MST
zito1553
Contacted armscor yesterday and  was told by Arnel bernardo that full size rock 10mm comes factory #20 recoil spring  and #23 main spring. Is that pretty much good to go?   I'm getting brass marks on top rear of ejector port. Anything I can do for that ?
I used to one of the guys that mixed it up alot.  Now I only change springs when I have issues.  I would say run with 20/23 unless you have a specific issue, and have reliable information that a different spring will correct said issue.
harleyhopper
#17
Quote from: sqlbullet on March 30 2015 03:20:26 PM MDT
I agree. New to you. Run several boxes through it and see. Most plinking ammo will be fine with that set up. I run the stock 20 recoil but 25 main. I would put the mainspring back to the 23 but I do shoot an ocassional hot load and simply put a 22 recoil in at that time. my Eclipse likes the 18.5/25 set up. Both have the flat bottom firing pin stops.
