Double Tap 155gr Speer Gold Dot JHP Pull-Down
Started by The_Shadow, February 07 2015 09:57:00 AM MST
Cartridge is from Ammo Manufacture: Double Tap 155gr  Speer Gold Dot JHP (provided by IC)
Muzzle Velocity: 1475 fps
Muzzle Energy: 749 ft. lbs
Brass Make/Headstamp: Double Tap DT - Nickel
Bullet Make/Weight/Construction/Info; Length 0.5395"/Dia. 0.4000": 155gr. Speer GDHP
HP depth 0.1600" / inside Dia. 0.2000" tapered / mouth Dia. 0.3000"
Actual weight 154.0 grains   (concave base) Crimp squeezed bullet to 0.3910"
C.O.A.L.: 1.2420"
Case: Diameter 0.4215" Crimp Diameter 0.4190" (Tight) Length 0.9880"
Powder Description/Positive ID/Type/Charge Weight: LongShot 10.0 grains
