Underwood 200gr Nosler JHP (2015) Pull-Down
Started by The_Shadow, January 02 2015 04:18:41 PM MST
Cartridge is from Ammo Manufacture: Underwood 200gr Nosler JHP (2015 provide by IC)
Muzzle Velocity: 1250 fps
Muzzle Energy: 693 ft. lbs
Brass Make/Headstamp: Underwood - Brass
Bullet Make/Weight/Construction/Info; Length 0.6755"/Dia. 0.4000": 200gr Nosler JHP
Actual weigh 200.0 grains  Crimp Diameter 0.3995"
HP depth 0.2170" / HP tapered cavity, inner cavity  0.1200" / HP mouth 0.2400"
C.O.A.L.: 1.2610"
Primer: Nickel color
Case: Diameter 0.4215" Crimp Diameter 0.4225" (Light Crimp)Length 0.9880"
Powder Description/Positive ID/Type/Charge Weight: LongShot  8.4 grains
mag360
That is same weight of the powder load from your pbr beartooth 200gr pulldpwn. Should be an honest load just under box flap.
Probably so, but well under what SwampFox was pushing... :o
msjayhawk
What ever happened to Swamp Fox? Just go belly up?
West Coast, Mississippi.
mag360
Owner passed away, unfortunately.  He didnt have anyone to take over for him.
