current EAA 10mm
Started by ct111, December 26 2014 06:00:16 PM MST
ct111
does anyone make grips that will fit the eaa witness elite match 10mm? i don't care for the factory grips
I think Intercooler has some sites that make custom grips for Witness guns.  The Elite Match uses the same grips as the full size.
sstewart
Quote from: ct111 on January 05 2015 04:29:40 PM MST
Yes there are
www. henningshop.com
Google Eric Grauffel
sstewart
#18
http://www.ericgrauffelonlineshop.com/en/home/198-xtreme-tanfoglio-grips.html#/color-black/model-large_frame/size-full_size
http://henningshop.com
http://www.czgrips.us/eaa_witness_tanfoglio.htm
https://coppergungrips.com
Hogue also makes the rubber finger grips for Tanfoglio (might be CZ) Intercooler has stated that he likes these.
I have no direct experience. I have not yet changed grips on any of mine.
Remember that many custom grips are for the limited or gold team, which have magwells. Therefore the grips are too short for your standard witness.
Dave84
Quote from: ct111 on December 27 2014 03:42:44 PM MST
hows the accuracy in the elite match 10mm ?substantually better than the standard full size steel 10mm ?
I have the Match and the Standard fullsize. I can say shooting them that Match is much more accurate for me having a nicer trigger on it. They are both accurate however. Never tried to bench rest them.
Match is more accurate.
But, I think alot of that is the trigger.  I keep meaning to drill and tap the trigger on my full size for an over-travel stop and then test again.
blfuller
I have seen some with the Hogue but from what I understand they need to be stretched quite a bit.
shootz
Copper here
I use a small rubber washer to keep'em tight.
ct111
where do you get the small rubber washers from ?
