Parabellum Research PBR 155gr Montana Gold JHP V Supreme VS10 Pull-Down
Started by The_Shadow, November 17 2014 01:22:24 PM MST
Cartridge is from Ammo Manufacture: Parabellum Research PBR 155gr Montana Gold  JHP V Supreme VS10 (provided by IC)
Muzzle Velocity: ?? fps (1450 est)
Muzzle Energy: ?? ft. lbs (723 est)
Brass Make/Headstamp: Star Line  – Brass
Bullet Make/Weight/Construction/Info; Length 0.5530"/Dia. 0.4005": MG 155gr
HP Depth 0.1150" / HP Dia. 0.1870" tapered / Mouth 0.2600"
Actual weigh 155.0 grains  Crimp Diameter 0.3990"
C.O.A.L.: 1.2560"
Case: Diameter 0.4215" Crimp Diameter 0.4210" (med crimp)Length 0.9890"
Powder Description/Positive ID/Type/Charge Weight: LongShot 10.6 grains
