Underwood 180gr Hornady XTP(11/2014) Pull-Down
Started by The_Shadow, November 15 2014 11:48:25 AM MST
Cartridge is from Ammo Manufacture: Underwood 180gr Hornady  XTP(provided by IC 11/2014)
Muzzle Velocity: 1300 fps
Muzzle Energy: 675 ft. lbs
Brass Make/Headstamp: Underwood  – Brass
Bullet Make/Weight/Construction/Info; Length 0.6400"/Dia. 0.4000": Hornady 180gr
HP Depth 0.2200" / HP Dia. 0.1370" tapered / Mouth 0.2235"
Actual weigh 180.0 grains  Crimp Diameter 0.3995"
C.O.A.L.: 1.2540"
Case: Diameter 0.4215" Crimp Diameter 0.4220" (med crimp)Length 0.9855"
Powder Description/Positive ID/Type/Charge Weight: LOVEX D037.01  13.0 grains *
*(LOVEX D037.01
High density, double base, ball propellant similar to Accurate No. 7
designed for 9 mm NATO carbine ammunition. Somewhat more
specialized in applications than D032 and D036, it is well suited to high
intensity cartridges. It is a good choice for .357, .41 and .44 Magnum
cartridges, when slightly less than full powder loads are preferred.)
Test results 12/26/2014
#1 (0.5 grain over highest AA#7 book loading)
Rainer 180gr HEX Plated HP
Star Line (new) COAL is 1.2550"
LOVEX D037-01 12.0 grains
From the Glock 20SF Factory barrel Wolff 22lb spring and recoil rod \
Velocity 1128 FPS
Case expansion 0.4320"
#2 (1.0 grain over highest A#7 book loading)
LOVEX D037-01 12.5 grains
Velocity 1238 FPS
Case expansion 0.4330"
#3 (1.5 grain over highest A#7 book loading)
LOVEX D037-01 13.0grains
Velocity 1285 FPS
Case expansion 0.4335"
NO SMILES! ;D  Primers OK
This powder maybe LOVEX D037.2, I have never seen it and don't know if it is even being shipped to the states or under other names!  The weight suggest AA#9, but it is clearly a different powder (with tear drops, flatten ball and micro spheres)
I will have to look back at the new Federal Trophy Bond pull-down. Similar?
Not it! That's interesting... we have another new powder.
Osageid
I will have to go to basement to look at my AA9.  Will post a pic soon
Osageid, I would welcome your efforts and pictures.  AA#9 did change since Western Powder became the marketing company.  This powder is different than any of the AA#9's I've seen.
I have the older AA#9 which is "Micro Beads" almost black color and the newer AA#9 is "flattened ball" with a gray to silver look.  However this powder has a different texture as mentioned.
Osageid
How is this?? Sorry it is with iPhone and not good camera
#7
Yes, that is the "NEW" AA#9 like I have on hand, but if you look you will not see those tear drop and long flattened rods that this powder exhibits.
Osageid
You are right!! BTW thanks for all your pull downs:) helps me !! :)
Your welcome, it helps us all and it is only part of why I like doing the pull-downs.  The main thing is to preserve the history through these documentations.
Now to find out if this powder that Underwood used here is LOVEX or if someone is making a new powder or importing this stuff.  But it is an interesting study! ;D
Pinsnscrews
#12
I think we have a match! Lovex Do32/04 From Intercooler's link
It's my DiMMe
#13
While that picture is in my files the LOVEX data suggest LOVEX D037.2 as a better powder fit performance wise and is similar to AA#9
LOVEX DO37.1 is similar to that of AA#7
Do they give a loading/pressure chart for that powder?
