Remington (10MM3) 180gr TC JHP Pull-Down
Started by The_Shadow, October 23 2014 08:36:27 AM MDT
Cartridge is from Ammo Manufacture: Remington (10MM3) 180gr TC JHP (supplied by Intercooler)
Muzzle Velocity: 950 fps
Muzzle Energy: 360 ft. lbs
Brass Make/Headstamp: Remington RP - Nickel
Bullet Make/Weight/Construction/Info; Length 0.6255"/Dia. 0.4000": 180gr TC JHP
Actual weigh 180.0 grains  Crimp Diameter 0.3995"
HP depth  HP 0.2150" / HP dia. 0.1420" (tapered inside) / mouth 0.2850"
C.O.A.L.: 1.2525"
Case: Diameter 0.4210" Crimp Diameter 0.4215" (medium crimp)Length 0.9875"
Powder Description/Positive ID/Type/Charge Weight: Power Pistol 6.2 grains
