Freedom Munitions Ammo 180gr RNFP FMJ (plated) Pull-Down
Started by The_Shadow, October 22 2014 07:29:38 PM MDT
Cartridge is from Ammo Manufacture: Freedom Munitions Ammo 180gr RNFP FMJ (plated) (supplied by Intercooler)
Muzzle Velocity: 1050 fps
Muzzle Energy: 440 ft. lbs
Bullet Make/Weight/Construction/Info; Length 0.5830"/Dia. 0.3995": 180gr RNFP FMJ
Actual weigh 180.0 grains  Crimp Diameter 0.3980"
MEPLAT   0.2550"   (slight concaved base)
C.O.A.L.: 1.2555"
Case: Diameter 0.4220" Crimp Diameter 0.4210" (medium crimp)Length 0.9870"
Powder Description/Positive ID/Type/Charge Weight: Win WSF 6.6 grains
>7.5gr's of this powder will put it on the edge of the pressure map?
Hodgdon shows 7.1 grains as max @ 1150 fps and 35,600 psi so 7.5 would be very close to the 37,500 psi possibly.
I have shot 7.4 and it performed much better. I wonder why Freedom doesn't switch to Power Pistol and get closer to the rating?
wingspar
Quote from: Intercooler on October 23 2014 03:38:25 AM MDT
Cost?
I wonder why so many manufactures overrate their ammo?  Don't they realize that forums like this, or anyone with a chrono can see thru that?
I've received 500 rounds of this stuff, and gone thru a box of it already.  It's fine for the range, and probably the cheapest 10mm ammo out there.  I can't afford to shoot Underwood all the time at the range.
Gary
