.41 Magnum bullets in a 10mm
Started by my_old_glock, September 17 2014 11:41:00 AM MDT
Very interesting results!   8)
What type of sizer are you using to resize the 41 cal to 40 cal?
my_old_glock
Quote from: The_Shadow on September 13 2016 02:01:02 PM MDT
I am using two LEE sizers. I first size to ~0.4055, then to 0.401
Thanks for the update on the sizers!
nickE10mm
my_old_glock
I noticed that some of my brass had a ring/crease around the base. The mark is not around the entire base. It is about 120 degrees around the base or 1/3. I did not mark the brass, so I don't know if it happened with the XTP or CL-SIL bullets, or both.
That almost looks like a sizing die ring, Some have had that happen with Hornady Dies and some with LEE
Push through sizing will dress that up.
PointBlank82
Has anyone done this with the 210 gr 41 magnum Gold Dot? RMR has some and I'm considering buying some to run in 10mm and 40 Super.
I haven't done it with those specific bullets, but it will work just fine.
