Well... Another suspected over-pressure 9mm thread which I doubt is it
Started by Intercooler, September 08 2014 04:50:02 PM MDT
http://www.mdshooters.com/showthread.php?t=159818
I'm trying to get the ammo to shoot in my pistols plus have The Shadow pull a couple down. Just like in 10mm... I think it's the pistols!
Since I am not a member there I can't view the pics of the brass.  Seems like the consensus is the gun is firing out of battery though.
Whenever I see this stuff I feel like I'm damn lucky  :o or I have great firearms  ;D
Ouch...Oh yeah.
Gun.
Gun, gun, gun.
That guys need to get to a professional and have his build checked out.
Quote from: Intercooler on September 08 2014 05:12:37 PM MDT
Not really.
A bunch of new enthusiast think since AR's are tinker toys that you can assemble from a bag of parts to a running, safe gun in 20 minutes, the same must be true for other cool guns.
And, if you have a bag of properly fit parts for a 1911, you can.  But you can't go buy parts that will properly fit.  Putting off the shelf parts together into a safe, reliably 1911 takes a ton of know how.
Based on this thread it sounds like this guy built the 1911 himself, and didn't get some fitting right.  Probably an issue with a disconnector that is a little too short.  I didn't read the whole thread, maybe a guru there did a real diagnostic for him.  Regardless, that gun isn't right, and since he built it best he could, he probably doesn't have the know how to fix it.
  I always hate it when the first finger gets pointed at the ammo  >:D
MKE ZQ1 124gr FMJ NATO (Turkey)
MKE – Brass was being used?
6.2 grains *
* (very fine irregular ball with tear drop/rod)(powder maybe LOVEX D032-04)
Also the ZVS 124gr FMJ had the same looking powder
It looks like the gun is either unlocking way to early
As I went back into my powder pictures I found a picture of the LoveX powder that sort of matches, I don't know if their other powders have similar looks, kernel shapes what have you...That's the trouble with the foreign powder types.  Not much in my database.
But as I did a little "google fu" this evening I found a LoveX reloading PDF to download and add to my files.  That PDF can be found here...
http://www.explosia.cz/en/streliviny/download/reloading_EN.pdf
Pinsnscrews
I have heard locally at the range by a few of the "Race Gunners" of some of the ZQ1 being oversized at the crimp or in the OAL. They allege to measuring and sorting rounds into batches. They use the steel plates next to where I would be for my IHMSA matches. I assumed since they were mic'ing rounds there at the range to make sure the boxes they had marked were correct...that they might actually know something...
It's my DiMMe
In the 9mm pull downs Reply #157 on: March 17, 2014, 05:33:58 PM
MKE ZQ1 124gr FMJ NATO (Turkey) 6.2 grains @ 1200 fps
also the
Reply #127 on: February 08, 2014, 03:45:40 PM
The ZVS 124gr FMJ used 5.4 grains @ 1080 fps
None of that craziness was experienced here with the ZQI Ammo  :D
Federal 115gr FMJ Aluminum Cased
Springfield XD 4" 1195, 1179, 1196, 1210, 1206. Average = 1197.2 FPS/ 366 LBS
EAA Elite Limited 4.75" 1240, 1251, 1238, 1245, 1241. Average = 1243 FPS/ 395 LBS
ZQI 123gr NATO New Box
Springfield XD 4" 1214, 1207, 1212, 1206, 1221. Average = 1212 FPS/ 401 LBS
EAA Elite Limited 4.75" 1255, 1255, 1253, 1249, 1248. Average = 1252 FPS/ 428 LBS
Last test when they were white boxed
ZQI 123gr FMJ
Springfield XD 4" 1239, 1198, 1182, 1215. Average = 1208.5 FPS/ 399 LBS
EAA Elite Limited 4.75" 1259, 1259, 1246, 1240. Average = 1251 FPS/ 427 LBS
http://10mm-firearms.com/factory-ammo/zq1-9mm-124gr-fmj-nato-load-made-in-turkey/
Here is my brass from today  ;D
gandog56
Guy seems to be insisting it's the ammo, not the gun. But I don't see how it can't be the gun.
I have to also wonder if his bore isn't fouled say with leading...
wadcutter
I've never seen cases bulge so much without rupturing. It's crazy, those 9mm cases must be pretty strong.
