10mm Rainer 180 gr and Longshot Data
Started by TXCOONDOG, June 01 2014 03:29:05 PM MDT
TXCOONDOG
G20, Gen 4, Factory Recoil Spring with 4.60" KKM Barrel
No signs of pressure and got me between 1200-1300fps that I was looking for.
Bullet: Rainer 180 gr HP
Case: Remmington .985"
Primer: WLP
Powder: Longshot 8.5 gr
O.A.L: 1.260"
Velocities: Average 1232 fps
Primer: WLP
Powder: Longshot 9.0 gr
O.A.L: 1.260"
Velocities: Average 1241 fps
Primer: WLP
Powder: Longshot 9.3 gr
O.A.L: 1.260"
Velocities: Average 1293fps
Just finished reloading using Accurate # 9 and same case, primer, OAL & bullet will post when time allows range trip  ;D
Midwest Shooter
I've started loading some 10mm rounds as well with Longshot and really like to performance so far. And that Longshot powder really has a bark :))
Glock 20 Gen4 10mm
Kimber Stainless Target ll 10mm
Sig Sauer 1911 Stainless Rail 45ACP
Sig P220 Carry 45ACP
Springfield Armory XDS 45
FNH FNP45
FNH FNX9
Ruger MKlll Hunter
TXCOONDOG
Yes it does (doubled up on ear protection) and it should have been called loudshot  :o
attrapereves
TXCOONDOG
I was in a hurry this morning with my reply.
Typically, Tumbling occurs with heavy hard cast  bullet using the stock Glock Barrel
BT8850
Thanks for the report TXCOONDOG, I've been loading just about the same load, xtreme bullets 180g hp, 8.7g Longshot, 1.255 oal, wlp. I don't have a chronograph so it's nice to see that you are getting the book velocities from your G20. I shoot them from my gen3g20 and 1006 and they've been great. How's the accuracy for you at 10yards? Also, for kicks, would you be able to measure one of the rainer bullets? Id like to see how close they are in length to the xtreme's I'm using.
TXCOONDOG
#7
My bench rest groups were 2.5" at 25 with the first load, 1.5" (even had one group of 4 at 3/4")with the second load and opened up to 3.25" with the last load.
I shot in groups of five and they were consistant with each session.
Free hand at 10yds were 2-3", because of shooter error (pulling down).
TXCOONDOG
#8
Quote from: BT8850 link=topic=2846.msg31837#msg31837 date=Also, for kicks, would you be able to measure one of the rainer bullets? Id like to see how close they are in length to the xtreme's I'm using.
I use nickel plated brass to ID my hunting loads
Correct me if I am wrong but I read the bullet length as 0.6160",  shows a concave base.  Nice bullets!
What are the bullet diameter readings?... (= < >) 0.4000"
TXCOONDOG
Length .616"
Diameter .400"
Max Velocities 1,500 FPS
Midway Product # 4632240
Just got 500 155gr XTP Bullets and wish I could find 180 or 200 XTP
BT8850
I agree with Shadow, they do look nice! Thanks for the pics and the report. They are looking very close to the xtremes, see pics. The xtremes are seeming to be a little shorter, in a string of 10 random ones from my box i'm getting .6085 - .6105 for bullet length. In looking at the pics I'd chock that up to the cavity on your Rainers being slightly bigger than xtremes thus making the projectile slightly longer to make 180g. The diameters are dead on the money though, every one was .4000. Looks like things are working out great for you accuracy and velocity wise with what you were aiming for, awesome!
TXCOONDOG
#12
The load did work out, but I'm thinking that I will get better accuracy using Accurate # 9 since it takes more powder (less void in the case). Not to mention, it would be noticeable if I inadvertently double charge.
I just ordered some 200gr XTP's from Midway and I'm looking forward to working up a hog load.
