UW 9x25 Dillon in stock
Started by Dave84, May 28 2014 08:05:51 PM MDT
Dave84
Haven't seen it available in ages but they have it in stock. Will probably sell fast.
bigdog72
thanks for the heads up I just ordered a few, I usually roll my own but my brass is getting tired this will help put a few more into the rotation
bigdog72
I just wanted to add a big thumbs up to underwood, I put my order in this morning and they already emailed me a tracking # and my ammo will be here monday! this is the first time i've ordered/used underwood if their ammo is as good as their customer service it won't be the last.
Russell, we did a pull down of the UW 125gr loading and it showed 800X, I wonder if he is still using the 800X?  Seeing how you load your own and are getting some of his newer stuff, maybe you can pull one to check the weight and powder type. 8)
Also I'd be happy to hear about your loadings and results... ;D
bigdog72
what puller are you using? I just throw my screw ups in an old cash box I've never pulled them apart. I've thought about getting the rcbs one but have never justified the need for it. iirc they were less than $20 at the local fun store I might run by there and pick one up.
#5
I have been using the RCBS made by Quinetics for 35 years, the small aluminum pieces that hold the shell casings have worn with all of the all the pulling I've done over the years, wrote to RCBS the other day and asked about getting replacements, they sent me brand new set for no charge!  I have no complaints on my RCBS equipment or their customer service!  ;D
I use a piece of 4x4 about 20" long and with it standing on end, I strike the end grain of the 4x4 block, this acts like a dead blow and helps keep the puller from getting damaged.  I try to strike it firmly, looking for bullet movement then as it starts to move out I soften the blows to have the bullet just fall out of the casing.   This keeps the powder from bouncing up into the shell holder and the threads of the cap.  Oh if you need to you could use a shell holder for the press (turned upside down) in place of the little 3 piece of aluminum chuck.
bigdog72
I stopped into a small town shop on my way back home today and picked up a puller, they only had one it's a brand i've never heard of before "quinetics corp" the guy there said he has sold a few and never gotten one back so for 18 bucks I figured its worth a shot. I'll pull one apart throw it up on my dumper scale and post pics on monday. ETA: after reading your post better above I guess its a rcbs before they repackage them.
bigdog72
#7
here are the results, it was a heavy 10.7 grns. my scale kept going back and forth between 10.7-10.8
Bigdog72, I transferred the pictures to my postimage account to preserve your pull-down.  Photobucket had a change of service...
Thanks for your documentation. :D  Looks like LongShot, if you chrono some of these, please post the results...
